water jacket?
  • macz
    • Jan 2009
    • 118
    water jacket?
    Well I took the boat for its maiden vvoyage....pretty fast on 6 and 7 cell promatch...water kinda choppy....Is there supposed to be water streaming out the side of the boat from the water jacket? There was no stream at all....it reached the jacket..but no stream. Sorry I'm a noob..
  • macz
    • Jan 2009
    • 118
    anyone?
    • Jeff Wohlt
      • Jan 2008
      • 2716
      Can you blow thru the system? What cooling can are you using and on what?
      Yes, you should be getting at least some coming out but not a hard stream.
      Just check your system from the pickup to the exit.
      www.rcraceboat.com
      jwohlt5362@yahoo.com
      • macz
        • Jan 2009
        • 118
        Yes I sprayed electric motor spray thru pick up and it spayed out the exit so I guess something was clogging it.....
        • macz
          • Jan 2009
          • 118
          It's the stock water jacket....how do u get the jacket off?
          • MAXAMUS
            • May 2008
            • 200
            the stock water jacket will come of with just a twist you may also need to hold it in a vice but be sure to protect the motor and don't over tighten.
            it may be a little stiff but try not to put pressure on the inlet and exit nipples as you may damage them
            Maxamus
            • macz
              • Jan 2009
              • 118
              What is it like threaded on there I dont have to unscrew anything? When I blew the motorspray thru the pick up all is well now thanks......
