Hi all,
I have a BJ26 that I am in the process of re-building. I am running speedmaster hardware, .186 flex drive, stock BJ motor with a castle hydra 120 ESC and 4S Enerland Lipos. Stock BJ radio gear.
I am having problems with the boat spluttering and farting around, basically just not running smooth, this causes the boat to jump about and stall out of the hole and is accompanied by short beeps from the hydra. I thought it may be interference so I changed over all my radio gear but the problem remains. Does anyone have any ideas what this may be? Could it be the hydra??? It is brand new! I have extended the RX cable to lengthen so I could run the hydra up front and disconnect the BEC cable. I have double checked that the soldered connections are clean and everything is shrink wrapped and water tight but I am scared that if the hydra is at fault CC may not honour the warranty now. Any ideas?
But what I do know is that when I run the same radio gear with my other boat I have no problems which seems weird to me. The BJ motor has 6 poles right? You would think the hydra would be OK with it, pretty commonly used motor/esc combination I would have thought?
