Problems using the programming card???
  • sn00p
    • Jan 2009
    • 72
    Right i finally received the card and hve tried numerous times to get it to re-arm after re-programming wit the card.
    Basically followed the instructions to the T. When i remove the programming card and re-power up the boat i do not get the arming tones??? ONLY way i can get it to re-arm is to hold full throttle when connecting up???
    By doing this i have NO idea what settings the ESC is at as im not even sure the esc has taken the card settings or by powering up full thrittle if i changing thesettings.
    All set as follows:-
    Lipo
    High cutoff
    idle cutoff type
    brake off
    high timing
    linear throttle
    ive tried all other combinations but still no joy? Im plugging the ESC lead in on top right side NO external power as im using the esc via the lipos???
    Anyways i got to run it 5s today and lost the hatch in 1 min lol..... manged to get it back eventually. All i can say is WOW
    REALLY want to get the programmer working correctly any ideas
  • sn00p
    • Jan 2009
    • 72
    Not to worry i now have it working correctly.
    For anyone having issues going by the instructions for ME didnt work. However if you leave the switch ON plug the card and then connect 2 batteries it seem to beep with the program setting. Now remove batteries then the ESC cord and replace in the RX. Power up with bateries and switch on and you should get the magic tone of the ESC arming
    NOT connect bateries with power button off then switch on... Just leave the switch on and use plugging the bateries in as powerup/off.
    Ive posted in both fastech and BJ threads.
    • Treydog
      • Dec 2008
      • 12
      Just got my lipos in today and like you, I followed the Proboat card instructions to the "T". No luck arming but had full rudder control. Then followed your instructions and it cranked right up. I have a pair of 35c 5200mAh lipos hooked up and when that prop turned over - WOW! is all I can say. Big difference from 6 cell nihm.
      Anyways, THANK YOU SO MUCH for posting this thread because you just made this so much easier for me.
      • sn00p
        • Jan 2009
        • 72
        Not a problem dude i love the net for valuable info.
        Just a warning i blew my ESC on 5s deffo remove the middle wire and wire in a battery 6v for the bec....
