Right i finally received the card and hve tried numerous times to get it to re-arm after re-programming wit the card.
Basically followed the instructions to the T. When i remove the programming card and re-power up the boat i do not get the arming tones??? ONLY way i can get it to re-arm is to hold full throttle when connecting up???
By doing this i have NO idea what settings the ESC is at as im not even sure the esc has taken the card settings or by powering up full thrittle if i changing thesettings.
All set as follows:-
Lipo
High cutoff
idle cutoff type
brake off
high timing
linear throttle
ive tried all other combinations but still no joy? Im plugging the ESC lead in on top right side NO external power as im using the esc via the lipos???
Anyways i got to run it 5s today and lost the hatch in 1 min lol..... manged to get it back eventually. All i can say is WOW
REALLY want to get the programmer working correctly any ideas
Lipo
High cutoff
idle cutoff type
brake off
high timing
linear throttle
deffo remove the middle wire and wire in a battery 6v for the bec....
