back to props again
  • kookie_guy
    • Jun 2008
    • 897
    back to props again
    ok, so with lipos on their way over on a plane right now, I gotta get the prop thing straight. I know a lot of people recommend the octura x642. However, it's not cheap, and being in Canada, rip off to get it from the US.
    What's a comparable CF prop out there to the x642?
  • kookie_guy
    • Jun 2008
    • 897
    anyone?
    Looks like the prop below has the same diameter as the x642 at 1.65", but the pitch is lower at 2.31" vs 2.64".
    Anyone try this one out? What's the size and pitch of the stock prop?
    http://www.offshoreelectrics.com/pro...od=grp-2317.42
    edit, looks like the stock prop is: Prop Size: 1.6 X 2.5 in Composite
    That means the size is a little bigger which is ok, but the pitch on the stock one is higher than the 2.31
    • egneg
      • 4664
      It is closer to a X442
      IMPBA 20481S D-12
      • kookie_guy
        • Jun 2008
        • 897
        is the x442 more conservative than the x642? Or is it the other way around?
        • egneg
          • 4664
          Yes the X442 has less pitch so less distance/revolution.
          IMPBA 20481S D-12
          • kookie_guy
            • Jun 2008
            • 897
            perfect. I don't wanna spend the money that a sharpened and balanced prop costs, so I would prefer to stick to the cf ones. thanks for the help.
            • 785boats
              Wet Track Racing
              • Nov 2008
              • 3169
              Kookie guy.
              You should be able to run a K45 prop on that setup. I would suggest getting one of them at the same time for testing.
              Cheers.
              Paul.
