anouther thing make it as light as possible but still strong enough to last a crash.
if you need a tester lmk
that's the plan, hehe. Not sure if I'm gonna mass produce these or not. Seems like there are quite a bit of components to machine so the pricing might not be as attractive as I hoped. If I don't do a mass run, I will offer this to people at my exact cost, plus shipping and any fees.
here's the modified design. Is this enough rudder sweep from side to side? It's at 40 degrees in each direction, combined total of 80 degrees movement.
Kookie, from looking at your 3D I noticed that there isn't much base support there... maybe you should add some metal to the base... it'll take a lot of force and the more base the better.
you mean the point where it all attaches to the transom? if not, which part are you referring to?
yes, where it attaches to the hull, where the 4 screws would be...
I think you'd need a bigger footprint in order not to have so much
localized force due to the long strut...
I will see what I can do to beef it up a bit without adding too much weight. They are the way they are so that they bolt right up to the stock location. I want these to be a direct swap with zero modifications.
that is totally fine.
what I meant was making the base instead of .5" x .5"
1" x 1" (numbers are an example)... leave the holes where they are it should help a bit.
hey just thinking out loud here, what about a dual rudder setup? obviously you'd have to drill holes to mount it up, but would that make it handle better or worse?
it would be more weight but tlr has the dual rudder design
hmmm, maybe a future project to keep in mind. I gotta force myself to stay on track here, hehe. I have too many ideas. Can't sleep at night cuz my brain is going crazy thinking of cool stuff to build/design.
