Can i use lipo?
  • cretandolfin
    • Jul 2011
    • 11
    Can i use lipo?
    hi!
    i would like to ask if i can use lipo without to set with ESC from nimh to lipo?
    is there any risk to damage the lipos or the esc?
    can we change the settings without the programmer from horizon?
    and something else also - do i have to change the flexshaft u joint?
    do i have to go for a better Steerable Drive Sys ?
    thank u for ur time!
    bill!
    grettings from crete greece!
    Don't say i can't. You mean i don't want !
  • JimClark
    • 5902
    Not as long as you don't take the battery down too low the question is do you know when to bring it in.
    Billy Graham
    • cretandolfin
      • Jul 2011
      • 11
      sorry but i don't know what u mean?
      sorry again but if u be more detail about my question?
      thank u for ur reply!
      • JimClark
        • 5902
        If you run it to low ( the lipo) you could damage the battery. The lipo setting gives you a low voltage cutoff so you don't damage the battery by runnign the boat too long
        Billy Graham
        • cretandolfin
          • Jul 2011
          • 11
          thank u again!
          but because i don't have yet the extra programer for the lipo its better to wait till i get it and then i make the right set up program to use the lipo.
          the manual says tha i can't use lipo if i don't change the setting with the programer?
          correct?
          thank u again!
          • JimClark
            • 5902
            Yes you can use lipos you just can't run it 10 to 15 mins and expect to be safe. Also do not run it at low throttle for extended periods of time. I would run it for two or three mins at a time then take some readings on the batteries to see how far you have run them down.
            Billy Graham
            • cretandolfin
              • Jul 2011
              • 11
              can i ask where i can get infos about the use - maintance - and the right use of the li-po battery?
              long lasting safe use and more stuff about lipo?
              thank u again!
              • sailr
                • Nov 2007
                • 6924
                What boat/esc are you talking about? If it's one of the newer boats, like Miss Geico, etc, it's probably already defaulted to lipos.
                Mini Cat Racing USA
                www.minicatracingusa.com
                • cretandolfin
                  • Jul 2011
                  • 11
                  Blackjack 26 br
                  i am wait for the BL ESC Programming Module for PRB3309 to make some changes to the boay esc and set it to lipo!
                  do we have any infos about this?
                  thanks alot in advance!
                  • sailr
                    • Nov 2007
                    • 6924
                    The Horizon website says you need to program the esc to use lipos! So yes, you definitely need the little programming card.
                    Mini Cat Racing USA
                    • cretandolfin
                      • Jul 2011
                      • 11
                      thank u again 4 ur reply!
                      what is the best settings for the black jack 26 with the esc programer card ?
                      do we have any sugestions?
                      7.4v 2c 5000amp 50c is the batterys that i am gonna use.
                      do we have any good settings for the motor?
                      i hope next week must have the programer for the unit.
                      stil i want to know what is safe for the battery and the proper use for it!
                      sorry but i am new here and new with the batterys so i wanna be very carefull for all this.
                      thank u again.
