I wanna go FAST!
Just ran my LiPo's, why do they even still make nimh's anymore? WOW what an improvement!!!!! Stock Hardware somewhere in the low 40's I will GPS after the hardware upgrade. I have to borrow a GPS in order to do so.
I can't get over the speed difference.Comment
What did I tell ya!! LOL... Fun stuff...Nothing like keeping you lipos warm and your prop wet!!
How did the BJ turn with the LIPO POWER??Nothing like keeping you lipos warm and your prop wet!!
First, I'm no racer. However, it turned fine. I almost rolled it one time. I let off the throtle and saved her.
Should I expect more or less turning with the inline rudder hardware?Comment
What is the best way to shorten a flex drive cable.I have never cut one of these before, and don't want to take a chance without checking!Comment
What I do is solder where I'm gonna cut about an inch to an inch and a half, then mark where I'm gonna cut it with tape, then dremel or hacksaw it off the solder is so it won't unspool. you wanna cut in between the inch to inch an one halfSamuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"Comment
I just tape it, mark it, wrap it in a towel and put it in my vise. Then cut the unneeded part off with a Dremmel (on highest speed with large cutting wheel). Then un tape it, clean up the edge where the cut was made, add a little solder to the end and install it...Nothing like keeping you lipos warm and your prop wet!!
Thanks guys, cut it this afternoon. No problems. Waiting on the epoxy to cure, then I will attach the new hardware. I will upload some pics after I get it completed.Comment
