I wanna go FAST!
  • gaboulware
    • Jan 2008
    • 16
    I wanna go FAST!
    Hi all-
    Here are a couple pics of my BJ 26. Currently running stock motor, esc, and stearable drive system. I have a drive and inline rudder system on its way as we speak with balanced x642. I haven't had a chance to put it in the water since going LiPo and I can't wait to see the difference. I have moved the ESC in front of the motor, and eliminated the tupperware container I hope to run it this weekend on 2ea. 2SP1 4900mAh Lipo's.
    Also, I plan on removing the turn fins and sealing the holes with 3M5200 or another type epoxy when I get the new drive.
    What should I expect before and after removing the turn fins and changing drive system?
    P.S. the yellow are sponges
  • domwilson
    Moderator
    • 4405
    A yellowing of the teeth....A deep feeling of remorse. Just kidding. Couldn't resist.
    Obrien has a the most experience with this. I would put dabs of silicone down before you mount the new hardware just to seal the holes. Depending on the hardware that you purchased, be prepared to play with battery placement and strut adjustments. What hardware are you getting?
    Government Moto:
    • gaboulware
      • Jan 2008
      • 16
      Randy Naylor at bby made the hardware. He said he was shipping it out today, should be here by Wednesday. (to SC from CA).
      • domwilson
        Moderator
        • 4405
        Is that custom made? Cool.
        Some guys are running fuller's, speedmaster, aeromarine and Twisted Liquid or a combination of the previously mentioned. What that means is there is alot of different things that can be done and I don't think there is a clear "winner" of what hardware is best. But ask specific questions and the guys here will be more than happy to assist. I'm running Fuller's for right now, but I have other hardware to experiment with.
        Government Moto:
        • txboatpilot
          • Oct 2007
          • 1494
          [ATTACH]3479[/ATTACH]
          [ATTACH]3480[/ATTACH]
          [ATTACH]3481[/ATTACH]
          [/QUOTE]
          JMO, I would leave the turn fins on for the first run, this hull gets loose when running x642 and lipo's...Even with new hardware... They will make turning more stable.. Otherwise expect SMILES from ear to ear!!!
          Nothing like keeping you lipos warm and your prop wet!!
          • gaboulware
            • Jan 2008
            • 16
            Thanks, I will leave them on. How much drag do they typically cause?
            Also, did you remove your battery trays, or did you just knock out the front side?
            • txboatpilot
              • Oct 2007
              • 1494
              Drag, yes a little bit. Mabey 1-2mph...
              I removed my bat. trays, put new ones in lower and longer, for better CG adjustment..
              • gaboulware
                • Jan 2008
                • 16
                Did you just use some balsa wood and epoxy to coat and secure?
                It seems the area holding the motor mount will then need extra support on the sides, correct?
                • txboatpilot
                  • Oct 2007
                  • 1494
                  Thin ply, and 20 min thin epoxy..I took the motor out and coated the wood wear it meets the hull... Mine is nice and stong around the motor mount area..
                  • txboatpilot
                    • Oct 2007
                    • 1494
                    When are you going to run those new lipo's??
                    • gaboulware
                      • Jan 2008
                      • 16
                      Nice, I have already applied some epoxy and carbon graphite thread around the hull under the motor and esc. Also along the back below the servo and transmitter to build some extra strength around the drive shaft. I used two different types of epoxy, hence the grey and clear resins.
                      When I replace the battery trays I will apply more epoxy around the sides of the motor mount.
                      Per PM request I have attached a few more pics of the inside.
                      • gaboulware
                        • Jan 2008
                        • 16
                        Hopefully tomorrow, pulling family duty today
                        • obrien
                          • Nov 2007
                          • 1264
                          I simply put velcro strips in the bottom of my hull for the batteries, and added some velcro straps to make sure they stay put.
                          You will need to detongue the x642 to get it to run the best.
                          I also cut 1" off of my turn fins.
                          I think the most speed I lost between testing with and without the turn fins was less than .5 mph. And that was before I shortened them.
                          My best run to date is still 52.8 mph. I know there is plenty left in it. I would say that if I get my prop right 55 is possible. On the stock motor I have run 45 mph on nimh batteries. I never ran the lipos with the stock setup.
                          • gaboulware
                            • Jan 2008
                            • 16
                            Sweet! I am going today to run her. I will let you know what the LiPo's do on the stock motor. I will pull the trays out when I get my hardware from Randy this week.
                            I am also getting my x642 from him balanced. I did not ask him if he was going to detongue it. Is detonguing it normal process when it is ordered balanced and sharpened ? Not asking if that is Randy's process, just industry specific?
                            • txboatpilot
                              • Oct 2007
                              • 1494
                              [/QUOTE]
                              No, detounging is not part of S&B... It is done on request, or by you.. I will shoot a pict. of detounged and not, so you can see the differece.. It is not hard to do..
