http://forums.offshoreelectrics.com/...ht=prop+tongue
this will show you the tongue on a prop. As far as removing mine, I just used a grinder to knock it off, then some 500 grit sand paper to finish it off, and balance it
You will need a prop balancer first. I also suggest you buy some playdoe so you can make sure each blade is the same shape. Once you have the blades the same shape, you can then balance the blades. You just grind on the front side of the prop (the side that doesn't have the cup). The best bet is to do it by hand so that you don't take off too much material.
