After a disastrous bench test with the stock drive I quickly found out that the universal will not take the power of bl or nitro.
I wanted to keep the scale looks of the steerable outdrive. Here's what I have done.
I removed the stock prop shaft.
Removed the stock bushings.
Drilled the stock out drive out to 1/4" or .250
Made a sleeve out of 1/4" k&S
Slide in a Stinger sleeve bearing, than cut it to the shorter length to fit the BJack.
Ran a new .150 cable with 3/16" prop shaft all the way to the new outdrive.
The new system is as smooth as butter!
I fired up a stock sv and a the sv powered Black Jack next to each other. The BJ is remarkably quieter than the sv. I hope to water test today! Pictures to follow in a couple of minutes.
