Roadrash's boat project
  • dana
    Banned
    • Mar 2010
    • 3573
    well the stuffing tube should slide into the strut... but if its the ose strut/rudder which i think it is it is meant to have 7/32 brass tube to fit. the blackjack uses 1/4 tube which is too big so you will need to cut the stuffing tube back. keep it as close as you can then you can use a piece of shrinkwrap to hold them together snug. i had the same setup on my last cat (1/4 tube to OSE strut/rudder) i actually cut it so close i didnt need the shrinkwrap but i used it anyways.
    • dana
      Banned
      • Mar 2010
      • 3573
      another thing you can do is after you cut the tube back you can get a small piece of 7/32 brass (about an inch or so) and use it to connect the two. the 7/32 fits snug inside the 1/4 tube and will help keep the strut and tube inline with eachother better if they dont line up perfectly. the only disadvantage to this is your teflon wont slide all the way into the strut, it will stop at the 7/32 but its no biggie really, just lube often
      • roadrashracing
        • 1462
        where I would have to cut it starts to angle up, it is not possible to remove the tube ether.
        • dana
          Banned
          • Mar 2010
          • 3573
          just put the strut up against the transom, then mark the tube where it meets the front of the strut housing. simple. now cut
          • dana
            Banned
            • Mar 2010
            • 3573
            mark the tube right there and cut
            • roadrashracing
              • 1462
              then just put the shrink wrap over it?
              • dana
                Banned
                • Mar 2010
                • 3573
                Yes. Butt the tube up to the strut and put shrink wrap over the seem to keep them together and inline
                • dana
                  Banned
                  • Mar 2010
                  • 3573
                  #23
                  should look like this
                  • roadrashracing
                    • 1462
                    #24
                    ok I see, this is coming out better than I thought, I'm going to let the paint settle a little bit more before I start putting other hardware on. I do need to bend a new steering rod, I just got some straight stock. Any picks would help of what other people got.
                    • G-UNIT
                      • 949
                      #25
                      How do load the pictures so they show up like yours on this sight.
                      • syncronized77
                        • Jun 2010
                        • 277
                        #26
                        I believe there is an paperclip attachment button in the advanced view of posting replies
                        Go Brushless or GO HOME
                        • dana
                          Banned
                          • Mar 2010
                          • 3573
                          #27
                          right you are. or you can scroll down to "manage attachments" and grab the pics you want
                          • roadrashracing
                            • 1462
                            #28
                            I have never setup hardware before so I don't know how it will preform, it seems to be a fudge off or is it right?
                            • G-UNIT
                              • 949
                              #29
                              You need to put a gap about 1/8" between the prop and strut, loosen the collet nut and pull the prop out to get the space required then retighten the collet nut. when the boat winds out the flex shaft gets shorter, the gap provides for this action, good luck and fun boating.
                              G.
                              • dana
                                Banned
                                • Mar 2010
                                • 3573
                                #30
                                Gunit is rite. Other than that it looks good. It may be a c hair off but nothing to worry about. You can get a piece of 7/32 brass about an inch long and slide it in the stuffing tube 1/2 inch and slide the other 1/2 inch into the strut if you want
