Roadrash's boat project
  • roadrashracing
    • 1462
    Well I got my blackjack and it was in really good shape, then I hit a dock and the hull got damaged, weel I was new at repairs and the hull was repaired and painted half ass, now I am left with a big mess, I got a lot of help am hits am I hope to get a nice looking boat.
    When I got it:
    Now:
    I just ordered the ose rear drive system so I hope that will make a big difference. I also read the area on painting so I hope I have better luck, I rushed it way to much, now I must pay.
  • roadrashracing
    • 1462
    do I need to sand all the white and blue off?
    • G-UNIT
      • 949
      No just scuff the hull with 320-400 wet or dry sandpaper to remove the gloss,
      then prime it, I used white primer so your colors are brighter, if your going to paint it black use a dark primer.
      after that drys wet sand again
      with 400-600 then shoot your color coat on and sand between coats w/600 or finer, when done, clear it and sand between coats with 600-800.
      when done with that I sand it down with 2000 useing plenty of water always.
      when thats all done use a 3m polishing compound and polish it with plenty of water again this will give you a nice high gloss finish.
      p.s the blue will come off.
      good luck and take your time.
      • tiqueman
        • Jul 2009
        • 5669
        What G said
        • roadrashracing
          • 1462
          Should have all my hardware and parts tomarrow
          • tiqueman
            • Jul 2009
            • 5669
            Awesome! Shes gunna be an entirely new boat.
            • roadrashracing
              • 1462
              I got the rudder package from ose do I wand the old top mounting holes in the hull to be in the top or bottom of the rudder?
              • G-UNIT
                • 949
                Use the same holes if possible. elongate if needed and seal well.
                • roadrashracing
                  • 1462
                  I already filled in the bottom holes ready to drill new ones
                  • roadrashracing
                    • 1462
                    parts are painted and drying. How do you cut the flex shaft and install a new liner, Also looking for picks of how the strut should be setup
                    • tiqueman
                      • Jul 2009
                      • 5669
                      Dremel w/ a cut off wheel. Give the liner a stretch and you shoudl be able to push it in.
                      • dana
                        Banned
                        • Mar 2010
                        • 3570
                        indeed i also like to solder the flexshaft where im going to cut it before i cut to keep the ends from unwinding or fraying
                        • roadrashracing
                          • 1462
                          can you solder it just like a battery or wire?
                          • dana
                            Banned
                            • Mar 2010
                            • 3570
                            you need either a high power soldering iron at least 40 watts( i would go for more) or what i use a blowtorch. clean and sand the area your gonna solder with anything you have handy like lacquer or paint thinner or nail polish remover even... just get it nice and clean, then i apply some flux, heat it up nice and hot then add your solder. easy
                            • roadrashracing
                              • 1462
                              Well not the best paint job but I think its better then what it was, there is some orange peal and puddling but its not bad for my first try. Its better then what it was! I got some mirrir flames for this bad boy.
                              Do I need to cut the tube down or mount the strut farter out?
