I tried to run a 3300/kv Bl and the Esc kept shutting down at full throttle, I'm thinking it might be the esc rev limiter thinking it's free running due to the high kv.
are you running that motor on 14.8 volts? If so thats 48,840 RPM
If that is what you are doing i would be happy there was a rev limiter and saved your esc.
If that is the motor you want to run try running the 2 batts in parallel and you will get half the rpm and alot happier system. But you need to stay under 45 amp draw
No I'm running it on 14 3600's integy intellects, which says after fully charged 20.562 volts...I assume those are unload volts.
wow, you are almost exceeding the voltage of the esc for one and your rpms will probably explode the motor as well. You are running 55,000 rpm unloaded or 67,000 rpm if you held the 20.5v. At this point your going to blow up all of your equipment!
Question for you, how much rc experience do you have?
I, use to run rc's years ago say about ten years, just getting back into as of this year, the brushless era enticed me once again. I ran that 3300 Kv in my Ep1 outboard SuperVee27 on a 4s lipo...It launches out of the water spinning a a range of props from a 632 to a 442 I had to make some trim tabs out of soft alum, so they could be more adjustable otherwise the thing would just tuck and roll all day.
Keep a few things in mind kv multiplied by voltage equals unloaded rpm, running that many cells is not a bad thing, but how you wire them will change everything
wire them in series will double the voltage more stress on the cells
wire them in parallel and you will double the runtime less stress on the cells
try running them in parallel and see how it works both packs red wire connected to the esc red wire and both packs black wire to the black wire of the esc. It will give you 24,000 rpm and run for a long time that way. Props will also play into the equation but that will be increase the heat of the equipment so you will have to keep an eye on that stuff too.
Yea, your right, the motor and batteries were hot, but the Esc was super cool
Iam new to all of this electrice talk and I just baught the BJ 26 and Iam haveing the same problem of not getting full throttle. I can only run the boat half throttle and Iam useing two venoem 3000 nimh pluged into the speed controller. What do I need to do?
