thoughts on blackjack 26 with sv motor on 3s
  • blackcat26
    High Speed Junkie
    • Sep 2009
    • 1598
    I was using the standard plastic proboat prop. Didn't want a metal one in case it met the boat i was trying to rescue. I think its close to a 642 but not sure.
    • video200
      • 837
      not shure if there is a prop with this one. so i figured id order part of the K series and the glass filled ones for a good start.
      wil be some testing to find the right setting for him
      • blackcat26
        High Speed Junkie
        • Sep 2009
        • 1598
        You should have no problem. You gonna have 2 3s pack in it or just one? Two will be pretty heavy and one will make the boat lean to one side pretty bad.
        • video200
          • 837
          the plan was 3s 2P. i have alot of 3S packs. so i figured if he ran a rino 4900 on each side it should be a little higher in the water then what my drifter S is with 4800 4s2p (same size boat).
          the rino batteryes are about 400g each so i hope to get away with the wight
