Running the bj26 with cc ice75 esc
  • bitton79
    • Aug 2008
    • 35
    Hi guys,
    I'm running my bj26 with cc ice 75A esc, stock motor, 5s 5000 mah lipo with bec, octura x642 and fuller's hardware.
    I just hit a rocket 59 mph but the esc went very hot (about 210F). I switched to an octura x640 prop, the motor rpm went up from 27000 to 30000, and the esc temp went down to about 165F. the motor was only warm-about 130F.
    I wanted to ask what would be a good temp to run the esc in that setup and in general, what's the highest temp you can run your esc without burnning it??
    I think of maybe switch to an octura x637 prop?
    I got all this info using the castle link as the esc has data logging (great feature...)
    Please assist?
  • Raydee
    • May 2007
    • 1603
    Patrick at Castle Creations says that the ICE esc's can be run up to 250* but for short periods. At 280* the controller will shut down to prevent damage to the fets. I would try to keep it under 200* to be safe. If it runs to hot maybe you need to go one size up (Ice 100).
    Team Liquid Dash
      • 7990
      Patrick at Castle has this to day about the ICE in aircraft:
      "The ICE controller will prevent overtemp conditions...boats are a little different -- because the surge currents are so high. In a boat it would be a good idea to keep the ESC below 150F."
      A small computer fan blowing on the ESC would solve that problem.
      • bitton79
        • Aug 2008
        • 35
        Thank's a lot guys
