rudder flutter
  • MAXAMUS
    • May 2008
    • 200
    rudder flutter
    my fullers hardware has now worn where the rudder feeds up the hole on the strut which i noticed effected its track in the water when running 6 cells making the boat fish tail quite bad so iam looking for some help here
    i know there is a small bush in the strut is this removable ? or even the shaft on the rudder is this removable ? if any of you guys have had this problem and have made a successful mod to rectify this please shed some light on this i am wracking my brains trying to improvise adapt and overcome this problem trying to source any everyday item that might suffice
    waiting to hear from you guys ........
    Maxamus
  • Chilli
    • Jan 2008
    • 3067
    If you email or call Mr. Fuller, I'm sure he would help you out. His contact info is on the bottom of the home page of his web site.
    Mike Chirillo
    www.capitolrcmodelboats.com
    • LiPo Power
      DJI Drone Advanced Pilot
      • May 2009
      • 3186
      http://www.drcwebservices.com/ffe/Default.htm
      He will.
      Canada
      • domwilson
        Moderator
        • 4405
        Got any pics?
        Government Moto:
        • LiPo Power
          • May 2009
          • 3186
          I had the same issue with my fullers and for small fee it was fixed by MR Fuller
          Canada
          • MAXAMUS
            • May 2008
            • 200
            unable to send away hardware as in the UK but i have made a very temporary repair just now by means of applying some heat shrink to the rod that fits inside the strut seems OK but am wondering how long this will last my bet not very going to the pond tomorrow and will see how things pan out
            Maxamus
            • domwilson
              Moderator
              • 4405
              There was a post somewhere here where someone had a similar problem. They used washers to shim it up.
              Government Moto:
              • MAXAMUS
                • May 2008
                • 200
                washers but the movement is lateral how would they work ??
                Maxamus
                • domwilson
                  Moderator
                  • 4405
                  I guess it would take up the play that would allow the rudder to "rock" from side to side. Have you considered drilling out the rudder hole and using a piece of k&s tubing to act as a sleeve?
                  Government Moto:
                  • 785boats
                    Wet Track Racing
                    • Nov 2008
                    • 3169
                    maxamus.
                    Dom has hit the nail on the head. A piece of K&S brass tubing that fits snugly over the rudder post is the go.
                    Drill out the strut to the right size install the tube add a drop of CA glue to lock it in place. Then refit the rudder.
                    Note; there are a couple of different wall thicknesses available so take the rudder along to the shop & try them out until you find one that has no play in it.
