Okay, I'm a little confused. You said you had the problem solved by stuffing 2 200 gram weights (14 oz) under the styrofoam but now your starting over with 1oz of sticky weight?
FWIW I drilled a 1/2 hole through the styrofoam towards the nose of the sponson and inserted 7 oz of weight (3.5 on each side) roughly 4" before the tip of the boat. It does help a great deal if the boat has a smooth run, otherwise it almost seems to induce more bounce if it hits any ripples or wake leading me to believe Panther6834 definately has the hull characteristic figured out. I really need to find a better location as my river area is less than ideal to run full throttle without fear of flipping or worse between the boat traffic, current, floating debri and jumping Sturgeons
which I completely forgot about.
