Proboat release new Blackjack 42" catamaran
  • fweasel
    master of some
    • Jul 2016
    • 4311
    In case you hadn't seen these yet...
    Polycarbonate Hull: Two-piece shoe box construction for extreme hull durability. Molded composite material is much more impact resistant than fiberglass.
    Polycarbonate Canopy: Durable 2.5mm polycarbonate provides a watertight seal and the thumb screws means no tape is necessary to retain hull on to hull.
    Spektrum Marine 4685 4 Pole, Water Cooled Motor: Rated at over 5 horsepower with 85%+ efficiency, this powerful 8S capable brushless and waterproof motor provides more than enough torque to hit 55+ MPH.
    Spektrum Smart 160A High Voltage, Water Cooled ESC: Able to handle all the power needed, it is programmable, water cooled, waterproof, and Smart.
    Aluminum Propeller Strut and Rudder: Both the propeller and rudder feature anodized aluminum. The runner has a special break away feature that protects the hull from damage in case floating debris is struck.
    S904 1/6 Scale WP Digital Servo: The high torque digital servo provides all the necessary power. Waterproofing makes sure the servo is up to the task of being in a boat without the risk of failure do to getting wet.
    Boat Stand: This custom molded plastic stand fits perfectly to the contour of the hull providing a rock stable platform to display or work on your boat. This boat stand will last for the life of your boat without the need to worry about water rotting a wooden stand.
    Vac-U-Tug Jr (13mph)
  • 1coopgt
    • Feb 2019
    • 415
    Looks interesting. I'm tempted
    • hughb
      • Jul 2016
      • 152
      Interested to hear peoples thoughts on the polycarbonate hull, a different way to go.
      • fweasel
        master of some
        • Jul 2016
        • 4311
        Will likely be fewer warranty claims than with fiberglass
        • 1coopgt
          • Feb 2019
          • 415
          Totally agree. Unfortunately if you hit something hard enough to crack it there's no real good way of fixing it unfortunately. Wonder how thick they are making the hull. Poly carbonate is some really tough stuff though.
          • hughb
            • Jul 2016
            • 152
            Arhh I see. Though would it be likely to flex more when driving it, changing the geometry of the boat?
            • fweasel
              master of some
              • Jul 2016
              • 4311
              We'll find out when people start receiving the boat, but I bet flex will be a non issue.
              • MADRCER
                • Feb 2017
                • 761
                Videos coming soon...
                If time allows and if the weather cooperates I should have some running videos uploaded on YouTube by the end of the week for those interested. Horizon gave me the go-ahead to move forward and start rolling them out.
                • 1coopgt
                  • Feb 2019
                  • 415
                  Very Cool . Curious to see what props will work good on it too.
                  • naveda_08
                    • May 2021
                    • 66
                    Wonder if she'll be faster than my 8s SonicWake, cant wait to see her with some decent props on MADRCER channel
                    • MADRCER
                      • Feb 2017
                      • 761
                      Good looking boat! 3/16 prop shaft that will take the famous dasboata props is always a plus... SSS 3674 motor for comparison as well.
                      • 1coopgt
                        • Feb 2019
                        • 415
                        How does the hull feel compared to the fiberglass hull of the Geico, flex or stronger.
                        • MADRCER
                          • Feb 2017
                          • 761
                          Definitely more flex than Fiberglass.
                          • oscarel
                            • Dec 2009
                            • 2135
                            How do you get away with no space between strut and drive dog?
                            • MADRCER
                              • Feb 2017
                              • 761
                              You talking about my Geico 36 in the video? It as 5mm gap in it. The Black jack has about 2mm out of the box.
