Proboat release new Blackjack 42" catamaran
  • Panther6834
    • Apr 2020
    • 708
    #31
    Originally posted by MADRCER
    Temp checks and trying to keep it on the water.
    Even from the most recent video (posted yesterday), she's still hopping worse than a jackrabbit. Have you tried moving the batteries further forward? I'm interested in this, but I don't care for jackrabbits (unless it's for dinner...and, maybe, not even then).
    ~ More peace, love, and kindness would make the world a much better place
    • 1coopgt
      • Feb 2019
      • 417
      #32
      Saw this guys video and the boat seems a bit calmer. Around the 19 min mark. https://www.youtube.com/watch?v=n8AbEo8jhGI
      • ACKopter
        • May 2021
        • 27
        #33
        Originally posted by 1coopgt
        I wouldn't worry to much. Most RTR's have dual rates built into the transmitter, I think its called so you can slow things down. Someone will correct me if I'm wrong.
        Originally posted by ACKopter
        Thanks, allthough I prefer actual user input I'll reach out to horizon as well.
        My apologies to 1coopgt, I was re-reading this thread and realized how poorly my post sounds, not my intention at all, I was still seeking 6s info and not discounting your input about the dual rate. I really need to get better at this whole written word thing as it rarely comes out as I had intended.
        • 1coopgt
          • Feb 2019
          • 417
          #34
          No problem . My point was on 8s as MrMad said you can slow it down with the transmitter throttle limit switch. You were asking about 6s which I'm sure the boat will run on but it will be slower. You would need to monitor the temps of the Batteries ,esc and the motor.
          • Panther6834
            • Apr 2020
            • 708
            #35
            True...but...he's NOT running at full-throttle (75% max, if even that), which he admits in the video. Our favorite "mad racer", on the other hand, was running full-throttle. What we don't know if whether he had the throttle switch set at 50%, or 75%, or whether he was manually not running full-throttle.
            • 1coopgt
              • Feb 2019
              • 417
              #36
              Yeah I though he mentioned he was at full throttle when he was running with the wind. But your right you don't know what setting he was on .He hit 51mph so who knows.
              I agree I like MrMads videos better.
              • MADRCER
                • Feb 2017
                • 759
                #37
                If he hit 51mph he was on the 100% setting. His boat at the 19 min mark isn't maxed out by no means It looks like he was at the end of his packs. Boat will only run low to mid 40's on 75% setting. It's stable on that setting but open it to 100% you better pull your pants up before you pull the trigger lol. Poly is going to flex under load more than glass so that may be why some of the jackrabbitting is. My prop is too deep in the water on mine in these videos and if i raise it then it's adding a lot of positive to it...a lot of positive... so i need bend my stuffing tube more to get proper alignment that I want with the strut. I didn't want to break anything on week one with it so i'm careful with what i do with it as of now. But everyone wanted a balls out run so that's what i gave them. It'll get better as time goes on everything is new to everyone.
                • 1coopgt
                  • Feb 2019
                  • 417
                  #38
                  Are ya going to be willing to write up what ya do to get her to run flat and fast?
                  • MADRCER
                    • Feb 2017
                    • 759
                    #39
                    Sure, if I'm able to get it to run flat and fast. It's pretty stable out of box until the 50mph range then it would get light in front.
                    • 1coopgt
                      • Feb 2019
                      • 417
                      #40
                      Cool
                      Ya I noticed there's no way to easily get into the front sponsons to add weight if you wanted which sucks. Could always drill a hole in each bulkhead and drizzle epoxy into the tips till the weight is right. Hopefully it won't come to that.
                      • ACKopter
                        • May 2021
                        • 27
                        #41
                        FYI, Got my account charge notice today so they're stateside and soon to be on the way! Anyone catch MADRCER's latest video, 62/64 mph on stock power with a prepped prop before going airborn into a spectacular flip? Starting to think I might be in over my head.
                        • 1coopgt
                          • Feb 2019
                          • 417
                          #42
                          You'll be fine. He's still using the stock prop. Just prepped by Dasboata . Real good run. He's starting to tweak the boat to see what she'll do. Impressive speed on the stock balanced prop.
                          • Ty89m
                            • May 2021
                            • 5
                            #43
                            I'm interested in this BJ 42, as well as the MG 36, though the single motor setup might be easier for me to live with as I'm not hugely concerned with big speed runs at this point. I also like the electronics setup in the new BJ 42, I've got a new DX5 Pro 2021 that will play nice with the ESC/Batts etc. Also seems the MG 36 might need some QC fixes and reinforcing, though perhaps it's improved since release. I suppose my main question is this: how is support on Proboat models long term? I'd like to think they'd support them for a few years at least, they're relatively simple electronics wise, so I suppose it'd be easy enough to utilize other electronics etc if it came down to it.
                            If I do end up with a new boat, think I'll grab the Traxxas Blast and rig it up to use as a recuse boat - seems it would work well in that role.
                            Anyway, thanks all!
                            • jhurlbert
                              • May 2019
                              • 74
                              #44
                              Just got mine! First thing is i lubed the flex shaft. Man it was a b to get out (had to use a screwdriver to pry it out of the strut) It looks like you cannot remove the strut bushing from the flex shaft without pulling the prop and drive dog off. I wonder how well the grease is going to get into the bushing without removing the prop and dog every time.
                              Well i just found a vid on youtube of someone talking about this, his way was to remove the strut with the shaft and then removing the prop and drive dog from the shaft. Leaving the bushing in the strut. Seems like a pain in the ass just to lube the flex cable.
                              https://m.youtube.com/watch?v=DlVvRht_v9k
                              • DBJr
                                • Jul 2012
                                • 108
                                #45
                                Just got a Blackjack 42 myself and like what was said earlier, greasing a shaft should NOT be this tough. I felt like I was going to break the boat trying to get it out.
                                Hopefully Steve will come up with a better alternative soon.
                                Current boats
                                Aquacraft Cajun Commander, Aquacraft Mini Alligator Tours - brushless, ProBoat Blackjack 9, ProBoat Impulse 9, ProBoat Recoil 17, ProBoat Blackjack 24, ProBoat Shockwave 26 BL V3
