Ouch!
  • mikiek
    • Apr 2017
    • 191
    Ouch!
    Well this has to be some sort of record. Not one to be proud of
    Got my Zelos on Tuesday. It's up for major hull repair today. Scraped a wall while rounding a pond. I'm pretty surprised at the amount of damage. Also kinda surprised not to see some glass at the joint. Looks like the deck is just glued to the hull. I would have expected a little more reinforcement.
    Looks like it wants to separate at the stern as well
    Thinking about trying to get some epoxy in the crack then clamp it. Follow up with clearcoating some epoxy over the crack. Part of the biz I guess.
    May your batteries never fail you...
    Mike
  • vinnyp
    • Mar 2017
    • 283
    I'll 2nd that ouch comment!!
    • mikiek
      • Apr 2017
      • 191
      One suggestion for you Vinny. Start slow
      Mike
      • fweasel
        master of some
        • Jul 2016
        • 4286
        Dayum. Sorry to see it. I fixed a crack in the seam exactly like that on my Impulse 31 last month, and a crack in my Voracity transom just tonight. I closed the crack with CA, then reinforced the joint from the inside with finishing resin mixed with chopped carbon fibers. Had I to do it all over again, instead of using the thin CA, I would use medium thickness to keep the mess down and hit it with an accelerator. The repair on the inside is pretty easy. Use PT-40 resin, warm it up in the microwave, mix in some chopped fibers, stir it up, and pout it down the inside of the hull along the damaged area. Prop the boat up to keep it from running and let it set in place overnight.
        I swung a turn wide with my Zelos on one of the first runs, but fortunately it was a muddy shore and no damage. I also launched it up a rocky embankment, so I got that covered too.
        2017-03-11 15.25.12.jpg2017-03-11 17.18.54.jpg2017-04-21 23.16.10.jpg2017-04-21 23.15.38.jpg
        • mikiek
          • Apr 2017
          • 191
          It was my stupidity for even being in that pond with the Zelos It's nice for the sailboats but too small for anything fast. Plus the hard edge all the way around. The cool thing is it's at work so we go out at lunch and do some RCing.
          Man what did you use to get the resin up inside the hull? There's a pool noodle stuffed in there, I'll have to get that out first.
          I'm still thinking about a layer or two of something on the outside. If anything, just to seal it up. I've been using WEST system epoxy on my sailboats, I can mix that thin and let it settle into the crack. It's going to look like poop but it should still be usable.
          Mike
          • mikiek
            • Apr 2017
            • 191
            Well phase 1 & 2 of the repair are complete. Per fweasel, I used some medium CA applied from the outside mainly just to hold the deck to the hull. I sanded down the joint a bit, I went thru the gelcoat but it looks better than when the gelcoat was cracked & chipped. Next I needed to epoxy the inside - no small feat. From the hatch it's about 10" towards the bow to the far end of the crack. My hand certainly doesn't reach that far. Guess I should have borrowed a kid.
            The brushes I use for epoxy are those flux brushes - a metal tube with bristles on one end. So I got a dowel and jammed it in the other end giving me a handle about 12" long. Slipping all that into the hull wasn't easy so I unfastened the electronics tray and pushed all that to the other side - hope I can put all that back together. Then I did quite a few dry runs, getting the brush inside the hull and all the way to the bow without touching the bristles on anything.
            My plan was to run a fillet along the joint of the deck and hull. I used a trick I learned from my sailboat build. The base WEST system epoxy is fairly runny - about like honey. I added some phenol thickener until the mixture was just barely runny. Then I took globs of that on the brush and slathered it all over the inside joint - front to back. When that was done I set the boat just about upside down, the side with the cracked edge a little lower than the other side. The idea is, before the epoxy sets gravity will pull it to the lowest spot - into the cracked joint. That's where it will harden.
            So the epoxy is curing, in the morning I'll figure out how to put a seal on the outside. I also noticed whatever the stuff is that holds the tray mounts to the hull is cracked in several places so I'll be doing some more epoxy work in the hull as well. I apologize for not taking any pictures, but once that epoxy is mixed there's no slowing down.
            Jeez, I never thought I would have to be doing this kind of thing on the first week of ownership
            Putzing around these forums (and also fweasel's pix in this thread) it appears that the deck to hull joint is a real weakness in the Pro Boat fleet. Several boats with almost identical cracks as mine. Makes me think if I get another Pro Boat I may go ahead and lay an epoxy fillet in the hull BEFORE I get into more trouble.
            Mike
            • fweasel
              master of some
              • Jul 2016
              • 4286
              The deck seam can be a weak point on any hull. You did hit a solid wall after all. Two of my electronics tray mounts popped loose after my on-shore excursion and I reattached them with JB Weld.
              • mikiek
                • Apr 2017
                • 191
                I found more damage this morning. A battery came loose at impact. It had moved off the tray and was up against a motor. The motor got turned to such an angle that the flex cable sheared off at the coupler. Had to get the piece of shaft out of the coupler - couldn't do that with the motor in the hull so I pulled the motor. Getting those mounting screws back in is going to be a bear. The other shaft looks a little expanded in the small area where you can see it exit the coupler. I may replace that one as well.
                People laugh at me sometimes when I start a new hobby. Besides the main item (bicycle, model, RC boat) I buy every spare part I can find. Tools too. When I ordered the Zelos I also ordered one of every spare part that HH had. Came in handy this time. On the bright side, I am getting a thorough tour of the inside of my boat
                Mike
                • fweasel
                  master of some
                  • Jul 2016
                  • 4286
                  Make sure your flex cables are on the right side and spinning in the correct direction. When looking into the hull, bow forward, the winds in the cables should make a ^ pattern, and NOT a V pattern. The expanded portion of the other shaft is what has me concerned. As far as the motor mounts, ball end allen keys are your friend. Attacht he mount to the motor and snug thos two bolts hand tight then insert the assembly into the hull. The two bolts that hold the mount to the hull are pretty easy to get started, but a long skinny set of needle nose pliers can help. Align everything so the flex cable slips in and out of the collet with no deflection, then tightening it all down. Some thread lock on those threads isn't a bad idea either.
                  • mikiek
                    • Apr 2017
                    • 191
                    Since I have a spare cable for each side, I will go ahead and replace the right side as well as the left. It could be OK but at the very least I will pull it and do a closer inspection. I'm considering sharpening the props while I have them off.
                    I believe I have read a few threads here where someone mentioned shortening the cables. I have no inclination to do that but it did make me wonder HOW it is done. Cutting the cable end of the shaft doesn't seem like a good idea and I don't see how cutting the threaded end would help anything.
                    I am trying to get the motor back in right now - "easy" huh? I do have some ball ends around somewhere but not sure any as small as that mount screw. One question, for lubing the bearings are you supposed to take the motor housing off or just put some oil on the shaft and let it run down inside?
                    A good day here for this sort of thing. Too windy to run, however I suppose I could be sailing.
                    Mike
                    • mikiek
                      • Apr 2017
                      • 191
                      Oh by the way, the epoxy did just what I wanted. It ran down the side hull and underside of the deck right into the hull/deck joint. There's a decent fillet there now and it's hard as a rock. It ain't gonna break there again If I could get a camera in there I would have snapped a few pix. I put a first coat of paint along the crack and sanded that down. I think I'll tape off that section and use an airbrush for the next coat. My paint mix is not a perfect match but I can live with it.
                      Mike
                      • fweasel
                        master of some
                        • Jul 2016
                        • 4286
                        A set of metric ball end hex drivers are essential tools for this side of the hobby, especially on a boat with twin motors tucked down in the sponsons. No need to cut cables. You pull slack out anyway when you set the gap between the strut and drive dog anyway. On the stock motors, you can only access the front bearing, sort of. Like you mentioned, oil att he base of the spindle and let it work its way in. The rear bearing can only be oiled by removing the rear cap on the motor while its out of the boat. I do it, but only on the rare occasion that the motors get submerged.
                        Glad to hear the epoxy work is wrapped up. The funny thing about battle scars, is you're a little less worried about the small scrapes and scratches afterwards.
                        • mikiek
                          • Apr 2017
                          • 191
                          A lot of scrapes & scratches today. I feel like I should post a pic of the boat - all back together. Thru sort of a comedy of errors I ended up with most of the insides on the floor of the garage this afternoon. Left motor, removed to get the bit of flex shaft out of the coupler. Right motor, removed to try to get stuff tube out. Right strut, removed cuz the flex shaft would not pass thru.
                          Replaced left & right flex shafts. Left was damaged during the incident. Right had a few broken strands - not sure how/why. Thank goodness for spare parts - went thru both my spare shafts in less than a week. Ordered more today. Made attempt at balancing/sharpening props.
                          This was an all day affair. Spent way longer than I expected. Very frustrating at times. Access to some parts was quite difficult. I did find my ball end drivers but even those didn't always help. Will be getting a driver set with a flex shaft. Will also be looking for a box end ratchet for the couplers. I've got to be able to do some of this type work in the field, or maybe at the beach. If you are really supposed to lube the shafts after 20 minutes of runtime I can see at least needing to be able to pull the cables off site. When I go RCing I'm talking hours not minutes.
                          I'm also frustrated by the amount of damage. Come on, I sideswiped a wall. It wasn't a Dale Earnhart
                          I'll try to mix up some paint tonite. If I have the ambition I'll go ahead and tape off and spray. That would leave the epoxy clear coat for tomorrow.
                          To make it all worth it, I did a few runs on the lake this evening. The motor is a lot quieter, but the boat seems a little slower. Both probably caused by my prop work. There was maybe a 1/4 ounce of water in the hull afterwards.
                          Mike
                          • REDLINE1
                            • Jul 2016
                            • 199
                            I found this testers paint to be a very close match (at least on my Zelos). I found it at the local ace hardware. It's a flat finish (maybe they make it in gloss) so I had to go over it with clear.
                            • mikiek
                              • Apr 2017
                              • 191
                              I may give that a try REDLINE. Always nice when you can buy a standard color. The gloss would not be a problem as I will follow up with some epoxy. That puts a nice clear shiny finish on things. I mixed some yellow a little while ago but it's not quite there yet.
                              The edge of the canopy has become my test surface. It's got several spots where I tried to match.
                              Mike
