I went ahead and taped and painted this evening. I want to get this over with. I'll do a little blending at the edges of the new paint, then clearcoat. Won't be good as new but it should work.
I noticed that I left the gap at the prop/strut a little bigger than recommended. I've closed it down to 2 mm. The problem is the impeller from the motor moves in and out about 1-2 mm so depending where that is my prop gap can be right on or a little big. I understand about the shaft getting some twist in it when the motor torques it and that the twisting pretty much stops when the drive dog hits the strut. But would someone mind explaining the implications of the gap being too big or too small.
Here's a shot of the right shaft that I happened to notice didn't look quite right. It was definitely about to have a problem. Can't figure out how it happened.
