Which inrunner are you using, Rafael? And why did you go to an in runner instead of the stock outrunner?
***NEW*** - Pro Boat River Jet Boat - 23"
I'm using a sample Dynamite 36x62 mm motor I had which is 2400kv. I have two boats. One is stock and the other lacks the outrunner and weighted flywheel. Why? Because I personally don't like the self right feature. In as many times as I've run the boat I can count in one hand how many times I've had to use the feature and it was on purpose after driving it to intentionally trying to flip it over.Rafael Lopez
Product Developer-Pro Boat
My Facebook https://www.facebook.com/profile.php?id=100010183246751Comment
I went to my local shop yesterday and got a river jet. I went to the pond in the afternoon and really liked the boat. But after 2 minutes I noticed a strange noice. I checked the boat and there were 4 magnets already loose in the boat.
Already with the first battery? Serious? After that, on 4s the boat ran full out for about 10 seconds. than the boat ran 50procent. tried different batteries but no success. sometimes the with the battery i could run a full battery normal, sometimes it hit lvc after 10 seconds with the same battery. I don't know what the problem is.Comment
Just got a notice from the hobby shop I bought my boat from to call Horizon. Called tech support than was told to check where the transom meets the hull and look for pinholes or if spots of light show thru. Was told to coat the area with CA glue to fix. Haven't checked my boat yet but it's advised to do so.River Jet 🚤Comment
If your boat is not taking on water and you don't plan to run it across rocks or asphalt like I do, then you should not have issues with the thin hull. When we get new hulls you can certainly get a new one and replace it at your convenience. I'd save it for a rainy day or for when its actually taking on water beyond being able to fix it with CA and accelerator.
We know the issues is there but it seems to me that it doesn't become an issue until people actually see it. We have very, very few boats that actually have holes. What appears to be holes is just light reflecting through the material.Rafael Lopez
Yup, as with anything jet pump powered, 1:1 or R/C models, if you don't have throttle you don't have steering. Takes a while to get used to but once you get it you don't forget.Rafael Lopez
Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco PowerComment
They were pulled because quite a few of us that bought one had issues like weak hulls, motor magnet issues, cracking impellers and melting pump housings.
Thankfully I haven't had an issue with the hull but I have experienced the other issues I mentioned with mine.Current boats
Aquacraft Cajun Commander, Aquacraft Mini Alligator Tours - brushless, ProBoat Blackjack 9, ProBoat Impulse 9, ProBoat Recoil 17, ProBoat Blackjack 24, ProBoat Shockwave 26 BL V3Comment
Last I checked, it is now mid October.
First it was June, then July, then August, then September and now October. There are also more parts, pump housing, hull etc that are backordered as well. I wouldn't think it would take this long to get these issues worked out. I am really starting to wonder if this boat was secretly discontinued. The next shipment of boats just says TBD.
Maybe the newly released boats like the UL-19 hydro and the soon to be released Veles 29 took priority.Current boats
