Rafael Lopez
Product Developer-Pro Boat
My Facebook https://www.facebook.com/profile.php?id=100010183246751 -
Thanks for the tip Rafael. Will give it a go. Does polishing help? I didn't polish per se, just cleaned it up with automotive polish.Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, ZondaComment
Rafael or Darin, i cant get an answer from horizon on if the struts sold on the site are sold in pairs or singles. Happen to know? Im getting a slight vibration in my right strut and would like to get ahead of it.. On that note anyone with machines planning on making upgraded struts? Possibly bulky enough for bearings?Comment
Check the flex to stub brazed joint to make sure it's true. I just replaced my cables with some new .187 x 3/16" x 3.125" propshaft cables from here on OSE. Dead true, no vibration at all. Plus, they'll allow me to use the longer hubbed props.
20160519_182849.jpgDarin E. Jordan - Renton, WA
[ATTACH=CONFIG]143433[/ATTACH]Comment
Heres all Ive done. (Stock)-Sharpened rudder, cleaned water pickups, upgraded cables, x442s x447s abc1615s abc1715s, y-split upsized water lines in and out, new hull/ hatch.. couldnt get the porpoise out of first one..(Madness begins)-swordfish 240s w/ cap banks no loggers, VHV bec, poseidon 1515 2200kv motors, hitec hs-5646wp servo, DX4S radio.... Tis a sickness for sure...Comment
I'd love to order some abc props does Chris have these in stock?
Sent from my iPhone using TapatalkComment
Rafael or Darin, i cant get an answer from horizon on if the struts sold on the site are sold in pairs or singles. Happen to know? Im getting a slight vibration in my right strut and would like to get ahead of it.. On that note anyone with machines planning on making upgraded struts? Possibly bulky enough for bearings?Rafael Lopez
My Facebook https://www.facebook.com/profile.php?id=100010183246751Comment
Ok, check the props and and them check to make sure that the main hex nut on the drive, which holds the pillow ball on place, is tight. Just be careful, if you over tighten it you will crush the socket washers that the pillow ball sits in. It just has to be hand tight.
Worst case, throw the prop on the other drive, swap 2 motor wires and see if it still vibrates. If just the one prop vibrates on either side, you have your answer.Rafael Lopez
One other thing that can happen is that the forward portion of the prop hub can be out of true. Not sure how others prep props, but I always square this up. Otherwise, when you torque them down, they can be uneven.
Just something to watch for.Darin E. Jordan - Renton, WA
I've been pecking away at my boat. I've been reinforcing it and getting it ready for the next level of mods. With a motor swap I know I can get around 90 mph with this thing. I put epoxy/chopped carbon down the seam and in the tips and from tunnel. This weekend I'm going to try and at least lay a base coat on it. Possibly clear it on Sunday. I can't wait!32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
