NEW Pro Boat "ZELOS 36" Twin Cat
  • forescott
    Hopelessly Addicted to RC
    • 2686
    #226
    Great job Keagan!
    • Keagan-Z06
      • Mar 2016
      • 970
      #227
      Thanks fellas. Having a rack made for the boats now.
      • Keagan-Z06
        • Mar 2016
        • 970
        #228
        • Keagan-Z06
          • Mar 2016
          • 970
          #229
          Not finished but will update as it comes along
          • Keagan-Z06
            • Mar 2016
            • 970
            #230
            • Keagan-Z06
              • Mar 2016
              • 970
              #231
              Don't know why some of my pictures keep posting sideways. But you get the idea! Tomorrow it should be finished after stain, seal, varnish!
              JPriami, notice anything here??
              • Yellow
                • Jan 2016
                • 81
                #232
                I like that!
                • Keagan-Z06
                  • Mar 2016
                  • 970
                  #233
                  Thanks man.
                  • JPriami
                    N4FOX
                    • 1675
                    #234
                    [ATTACH=CONFIG]142119[/ATTACH]
                    [ATTACH=CONFIG]142120[/ATTACH]
                    [ATTACH=CONFIG]142121[/ATTACH]
                    I sure do! Looking good.
                    • TheShaughnessy
                      • 1431
                      #235
                      that repair came out great, colors blended great cause I can't see any sort of line.
                      • Keagan-Z06
                        • Mar 2016
                        • 970
                        #236
                        One last pic before I try and hit the waters tomorrow. My packs got delayed so the Zelos and Voracity date will be postponed another couple days.
                        • JPriami
                          N4FOX
                          • 1675
                          #237
                          Well I'm having a heck of a time with these outdrives. The grease keeps getting sucked out as I drive. First it was leaking bad where the outdrives meet the transom. I silicone that area. Now I see its also getting sucked out where the adjustable part of the drive goes into the fixed area. I've only driven the boat on the lake 3 times now. It's causing excess wear on my flex cables also.
                          • Keagan-Z06
                            • Mar 2016
                            • 970
                            #238
                            Have you adjusted strut by any chance?
                            • Keagan-Z06
                              • Mar 2016
                              • 970
                              #239
                              How do you guys use 3 straps when packs are all the way forward? Or is it just two?
                              • JPriami
                                N4FOX
                                • 1675
                                #240
                                It did this out of the box on the first run. I adjusted the struts maybe 0.5mm the 2nd run & it did it. No adjustments for the 3rd run and it did it.
                                I just removed both of them for inspection. It appears to be leaking from where the piviot ball screws into the long shank of the outdrive. It was really loose at that connection. That's where the bulk of the grease was & those threads were covered in it. Im guessing water passing by it at a fast rate creates a vaccum. Then the grease gets pulled out. I'll clean the grease and use a little locktite on reassembly.
