Bought a ProBoat Stealthwake to play with
  • arrover
    • May 2015
    • 322
    #31
    Haha! Thanks guys. It's been a lot of fun. Kind of different from the bigger boats that we're always talking about. Rafael, has there been any talk about adding the brushless version to the Pro Boat lineup? I'm not sure how that would fit into the lineup and how much you would have to charge, etc, etc. But I do think that it would be a really fun boat. I think a Stealthwake with a brushless motor and a water cooled ESC that did around 25mph would be an amazing RTR boat. Maybe eliminate the battery and charger to bring the price point back down a hair. 2S max battery. Oh and then there's the fiberglass Stealthwake 30 that you need to develop....
    ProBoat Zelos 36 Twin, Voracity 36, Impulse 31, Stealthwake 23, and HobbyKing Flowmaster Videos
    • rw442
      • Aug 2013
      • 121
      #32
      Nice run keep it goin like all your videos.
      • arrover
        • May 2015
        • 322
        #33
        This hull isn't really made to go these speeds. Yesterday I was running around 30mph with an Octura M645 on 2S. I brought the boat in and noticed this fairly bad damage where the rudder mounts. This aluminum rudder even has a backing plate behind it but the hull just isn't designed for theses high speed stresses. I bet that this area of the hull was damaged from some of my faster wrecks and it finally gave way yesterday. The boat actually still runs fine and I continued to run it after I found this crack. I still like this boat at least as much as some of my much bigger faster boats. Maybe even more. This has been a great project but my opinion is that for maximum FUN, this boat is best left close to stock. Ideally it would have a small water cooled brushless motor and ESC and a metal prop. Keep the speed around 20-25mph and maintain that fun rough water ability. I believe that the Impulse 31V2 stainless prop is the same pitch and diameter as the stock plastic Stealthwake prop (1.6x 40mm).
        • Tamelesstgr
          • Jun 2014
          • 1516
          #34
          Oddly I realized that when starting to design the color scheme for my mono build it looks strikingly similar to the Stealthwake.
          NEVER SATISFIED RACING
          Fine Design 32 V-Hull 4082+6s
          • arrover
            • May 2015
            • 322
            #35
            It does! Looks great though!
            • be8843
              • Mar 2016
              • 47
              #36
              Hi, I'm putting a stainless water outlet on my steathwake and was wondering if you used a hose clamp to connect the water outlet to the tube?
              • fweasel
                master of some
                • Jul 2016
                • 4285
                #37
                If the cooling hose fits tight enough, no need. If you're uncertain, or want to be sure, a clamp or zip tie won't hurt anything.
                • arrover
                  • May 2015
                  • 322
                  #38
                  Just looked at my boat and I do not have a clamp or zip tie on the line. You usually don't need them.
                  • be8843
                    • Mar 2016
                    • 47
                    #39
                    Good to know, thanks
                    • skeeler
                      • Jul 2007
                      • 198
                      #40
                      A couple of the posts in this thread suggest that the Stealthwake was designed specifically for rough water. Is that the case?
                      Revolt 30, River Jet, Southampton Tug, Outcast 6S BLX, 8ight-E, Ten-SCBE, 22 2.0.
                      '09 Miata.
                      Ibanez basses and guitars. Mapex drums, Zildjian cymbals.
                      • arrover
                        • May 2015
                        • 322
                        #41
                        The Stealthwake is narrower than most boats of the same length and it has a deeper V. I gather that those things are what help it handle rough water better.
                        • be8843
                          • Mar 2016
                          • 47
                          #42
                          Sides are higher than most boats also.
                          • skeeler
                            • Jul 2007
                            • 198
                            #43
                            I see. Thanks.
                            You mean the freeboard, right?
                            I can see how that would help.
                            A 30-inch, brushless, fiberglass version of the Stealthwake would be of interest to me.
                            '09 Miata.
                            • be8843
                              • Mar 2016
                              • 47
                              #44
                              Yes, I would like to see a 30 inch brushless version myself.
                              • arrover
                                • May 2015
                                • 322
                                #45
                                Absolutely! I would love it if it was a little longer even. Like 32"-36". Rafael has one that he tested for a while but I believe they decided against producing it. I think that's what he told me anyway.
