** New Zelos 48 Brushless Large Scale Cat From Pro Boat**
  • fweasel
    master of some
    • Jul 2016
    • 4288
    #316
    Cool. Those are the quick and dirty way to make an EC5 ecosystem work with either 2 or 4 packs on the stock 120A ESC. The die hards will tell you to switch everything to bullet connectors so it can all be hooked up with fewer connections and less resistance, but I don't think it's a big deal running the stock ESC and motor.
    Vac-U-Tug Jr (13mph)
    • forescott
      Hopelessly Addicted to RC
      • 2686
      #317
      Happy birthday to me! I got a great deal on this used proboat zelos 48. Been wanting one of these for a while now....
      • fweasel
        master of some
        • Jul 2016
        • 4288
        #318
        HBD to you indeed
        • IRON-PAWW
          • Oct 2011
          • 314
          #319
          Nice! Still looks shiny! I don't think it was used much. All the better for you :-) Run it yet?
          PERTH AUSTRALIA
          • urbs00007
            • Jun 2011
            • 826
            #320
            [QUOTE=Chado2448;667743]Started repairing and blueprinting my hull. After a few minutes blocking the sponsons this is what I ended up with. There are quite a few waves and hooks on them. Hopefully after I'm finished this will cure my bounce and get my speed where it should be. image.jpg[/Q
            • urbs00007
              • Jun 2011
              • 826
              #321
              [QUOTE=urbs00007;688587]
              Originally posted by Chado2448
              Started repairing and blueprinting my hull. After a few minutes blocking the sponsons this is what I ended up with. There are quite a few waves and hooks on them. Hopefully after I'm finished this will cure my bounce and get my speed where it should be. [ATTACH=CONFIG]144506[/ATTACH][/Q
              did blueprinting your hull make the boat run better? i have flattened my hull bottom but havent run it yet. i will also put strut on back of boat and rudder on left to counteract prop torque.
              • eric113
                • Sep 2011
                • 323
                #322
                Is the 48 worth getting? I might be looking at used one.
                • forescott
                  • 2686
                  #323
                  Yes, it's an awesome boat! I got a used one for 650. I love it!
                  • carbow
                    • Mar 2017
                    • 6
                    #324
                    new paint
                    New color.
                    • urbs00007
                      • Jun 2011
                      • 826
                      #325
                      Originally posted by carbow
                      New color.
                      [ATTACH=CONFIG]159393[/ATTACH]
                      what drive system are you running? any video?
                      • carbow
                        • Mar 2017
                        • 6
                        #326
                        Everything stock except for Octura X452 prop from DasBoata.
                        • urbs00007
                          • Jun 2011
                          • 826
                          #327
                          I'm in the same boat as you PAWW ( pardon the pun ). I've adjusted the strut and battery position a million different ways and it is still bouncing terribly. Can some one share a pic or two of their strut placement? Here a video of mine, it does the same thing no matter what adjustments I make, glass or chop, don't make a difference.
                          https://m.youtube.com/watch?v=91JUEfyzOw0
                          did you get rid of that bouncing? mine did the same thing.
                          • dasboata
                            • Dec 2010
                            • 3152
                            #328
                            John block sand the bottom raise the strut see if that helps
                            • Aquanaut
                              • Nov 2016
                              • 7
                              #329
                              Does anyone know if Proboat has a replacement in the works to replace the Zelos 48?
                              I really like that size boat.
                              Glenn
                              • carbow
                                • Mar 2017
                                • 6
                                #330
                                in the water
