The NEW Proboat motor and ESC?
    • 9488
    #76
    Who said anything about a "new motor design"?
    It's just another rebranded motor that Dynamite decided would suit their RTR needs, being supplied by the lowest bidder.
    You go up in KV, you generally lose torque, given the same basic physical size, so you prop down a bit and get your speed from prop speed rather than pitch. Pretty healthy difference in overall RPM between 1865kv and 2000kv on 4S.
    IMO it's only healthy if you can use the same props otherwise you need to prop down and only maybe get to the original speeds of the AQ2030 setups being its only maybe 7% faster in kv with less torque
    in other words, if I cannot utilize the little bit of extra rpms then I don't think it would be a healthy difference
    is this the same motor as in the Kyosho boat ?
    think I will hold off and see how others do with this motor before ruling on it for NAMBA20
    • Doug Smock
      Moderator
      • 5272
      #77
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
      • TheShaughnessy
        • 1431
        #78
        Healthy meaning significant? Some boats run better with smaller props
          • 9488
          #79
          Not my setups if I have to prop down ... with the AQ2030 I could prop up but that is not needed because they run so well now
          • TheShaughnessy
            • 1431
            #80
            I would say don't get this motor then. I wanted to check it out, got a good deal, had to have it. I dont mind be a test dummy at times.
              • 9488
              #81
              Let us know how things go Michael
              I don't see any reason I couldn't use the same props on my boats now and just swap out the AQ2030 with this PB2k
              • montymike
                • Jul 2012
                • 774
                #82
                First instinct is to prop up, so go to a 40-38 on my boat do I go 2 mm on strut from flat to make up for smaller prop size? On my new
                Bj. 29
                  #83
                  ...I don't see any reason I couldn't use the same props on my boats now and just swap out the AQ2030 with this PB2k
                  Really? How about less torque to swing the same prop? When the FE30 first came out several of us tried different motors to see which worked best. We could not get the speeds we wanted with the 1800 motors even with large props. We put in the 2030 motors, propped down and went 2-4 mph faster.....
                  • Darin Jordan
                    • 8335
                    #84
                    With all due respect, you are making comments as if you don't truly understand how electric motors actually work. I've followed your previous conversations so I think I know better than that. Not sure where the disconnect here is coming from?
                    I'll say it again... The AQ "2030" is NOT a 2030KV motor... it's 1865 at best. I recall some of the original ones testing to 1930KV, but I've NEVER seen one test over that... EVER, and I've tested a LOT of them. ALL of the recent ones I've tested are in the 1865KV range.
                    You have ONLY been able to get away with running the ridiculous sized props that people seem to run with these (X447, etc) BECAUSE these ARE NOT 2000KV motors! You are propping for a motor significantly less than that.
                    If you don't think it's significant, do some math:
                    1865KV * 14.8 = 27602
                    2000KV * 14.8 = 29600
                    That's 1998 MORE RPM...
                    Seriously trying to suggest that a prop change isn't in order??
                    I really, REALLY, don't think many of you put enough emphasis on just HOW important that little wheel on the back of the boat really is. NOT just in speed, but in exit speeds, cornering speeds, HANDLING, etc.
                    Darin E. Jordan - Renton, WA
                    • T.S.Davis
                      • 6220
                      #85
                      We all know that with the 2030, heat is the devil.
                      Are these about the same? Can they handle more/less heat? Does anyone really know?
                      Noisy person
                        #86
                        FWIW, using motor temperature to determine a safe amp draw has little value without context. Last summer, with ambient temps in the low 100s and water temps around 90*F, my motors (Limited and Open) would come back after 6 laps around 130*F. No problem, this is well below the point of motor damage. A couple weeks ago, with both ambient and water temps in the 50s, the same boats had motor temps below 95*F after six laps. No changes other than the date. A setup which is fine in the winter or in colder climates may burn up on a hot summer day on a warm pond. Too, the time between hitting the beach and measuring the temps matters. The ESC in particular can cool off quickly, after five minutes it can be 50* cooler than immediately after shutting down.
                          • 9488
                          #87
                          so this PB motor has "maybe" 7 to 8% more rpms vs the AQ2030
                          and my AQ2030 powered
                          PSpec Mono runs 95-100* after a 6 lap heat
                          PSpec OPC runs 90-95* after a 6 lap heat
                          PSpec Rigger runs 110-115* after a 6 lap heat
                          LSH runs 105-110* after a 6 lap heat
                          that this new PB motor cannot swing those current props without heating up to burn notice ??
                          I would think that a new motor design (or relabeled) would be more powerful with a little more rpms
                          That's my point all together
                          I'm the one who brought FE to District 20 and we are always looking for new things
                          and as you can see from my setups and if you see them run you would understand I know what I'm doing
                          I just cannot drive worth a damn
                          at best the PB2K motor is only 7% faster in rpms and if it cannot swing my setups now without burning up, then ..... ....... .......
                          • montymike
                            • Jul 2012
                            • 774
                            #88
                            So Darin , on bj. 29 v3 stock prop and smaller ?
                            • Darin Jordan
                              • 8335
                              #89
                              No... the boat was horribly under-propped with the 1800KV motor... That's why you could run a BJ29 around until battery cutoff, in stock trim on 4S, without burning things up. Exactly the way a RTR should be. :)
                              • Darin Jordan
                                • 8335
                                #90
                                Whatever you say...
