Wanna go faster
  • AZpdljumper
    • Apr 2009
    • 90
    Wanna go faster
    I keep hearing these boats go 35mph stock. After my first outing I changed the
    prop to a 42/55 grim racer. Iam running 3800 Nimh EP packs and on the first run
    with gps only managed 29mph. Should I expect more mph with this combo? Want to optimize this setup before doing more mods Lipo's Motor.
    Thanks for the info.
    SV 27 , Mean Machine, Prince 26,Vac-U-Pickle
  • z400
    • 1311
    Look into the Ammo 36-50-2300 motor which works with the stock esc.
    Boat will be noticeably faster with this motor.
    I havent looked and compared the two props, but the prather 220 is a great prop for the Supervee.
    Z
    KBB34" Mono - Fast
    ToySport Triton- Not as fast
    • nate
      • 1652
      Buy a Feigao 12 L 2084KV, Then run an x442 with the stock ESC, you should easily see 42-43mph, Thats the setup I use on my white SV27.
      The Ammo2300 with an x445 of m447 will probably get you 39-41mph on lipo's.
      Either way will be very noticiable!!
      LMT
      LehnerMotorenTechnik.com
      • z400
        • 1311
        I really want to find a different set up that will get me 40-45mph speeds.
        So the 12L with the stock esc and a x442 Nate?
        Z
        KBB34" Mono - Fast
        • nate
          • 1652
          Yes, Id run two water pickups as-well, you should see 40-41mph on this setup,
          on a calm day that is..
          LMT
          • Leskimo85
            • Apr 2008
            • 81
            UL-1 motor and esc is a great combo! I reached speeds of 45 using a carbon 48. Plus the UL-1 esc has a low voltage cutoff so you can run lipo's without worrying about ruining your batteries.
            • nate
              • 1652
              Good point, that would be a great setup.
              LMT
                • 9488
                Your biggest set back no matter what motor you get could be your batteries..
                I run the stock motor, esc, and CF48 with 30c lipo batteries and run a constant 40mph!
                • AZpdljumper
                  • Apr 2009
                  • 90
                  Well ordered the ammo motor prop and water jacket to start. Will be changing
                  to lipo's after I figure out which charger to buy. Any input ?
                  Thanks again, Ken
                  • z400
                    • 1311
                    Go with about anything that Hyperion makes.
                    Excellent company.
                    Z
                    KBB34" Mono - Fast
                    • nate
                      • 1652
                      Z's right.. You can get them here:
                      MaxAmps.com
                      Tanic Packs.com
                      Or even better.. rcLipos.com has them!
                      LMT
                      • AZpdljumper
                        • Apr 2009
                        • 90
                        Thanks for the info looking into the Hyperion Eos0606i Ac Dc charger and the zippy lipos. Stimulating the economy I guess.
                        • nate
                          • 1652
                          Nice. Try TowerHobbies they have black CF SMC 28C 7.4v lipo's for 90 bucks ea.
                          LMT
                          • z400
                            • 1311
                            Those zippy's fit the bill and will make your boat scoot!
                            Z
                            KBB34" Mono - Fast
                            • motoxbob11
                              • May 2007
                              • 190
                              I love my Hyperion ac/dc charger and I am running a UL-1 motor with the original 45 amp speed control and a Grim 42x55 prop. No heating problems yet and it will run in the low 40 mph range with no problem. A CF45 prop runs even faster but unless the water is glass it is just out of control.
