Question about flex cable
  • riverside4
    • Jul 2008
    • 49
    Getting super V ready and wanted to upgrade flex shaft to this
    http://www.offshoreelectrics.com/pro...svcable&cat=52
    Would this be the correct bullet nut to use or anybody have any recommendations as i lost the stock nut.
    http://www.offshoreelectrics.com/pro...let-nut&cat=52
    Also have been using cf45 and and cf48 and they dont fit snug on stock shaft and there is not much threads showing when i use these if i upgrade will this fix this also
    Thanks for the help
  • Steven Vaccaro
    • 8723
    That nut fits the stock shafts, this one is for the upgraded one.
    http://www.offshoreelectrics.com/pro...od=oct-oc6pnmm
    The upgraded shaft uses a sorter stub shaft, it makes it easier to adjust the drive trim angle.
    • riverside4
      • Jul 2008
      • 49
      Thanks for the replies do you know when you will have nuts for the upgraded shafts in so i can get both at the same time.
      Also not sure what you mean by Just slide some teflon the whole length of the shaft as i use grease is it the same thing.
      • Steven Vaccaro
        • 8723
        Nuts will be in later this week. The teflon goes inside the stuffing tube, the cables turns inside it.
        • riverside4
          • Jul 2008
          • 49
          Got my order very fast thank you. question looked all over site is there a how to for replacing the shaft. from what ive read ill have to remove the bushing from the strut to install the Teflon tube or will it go right in and trim to length not sure any help would be great.
          • z400
            • 1311
            Remove the bushing in the strut and remove the teflon liner that is in the stuffing tube if there is already one in there.
            If your not sure if there is one in there or not, you may have to remove the motor and slide something down the stuffing tube from inside the boat to push out the teflon liner.
            Once the old one is out if there is an old one, slide in the new one and cut it to length.
            Install the bushing and then re install the cable.
            Z
            KBB34" Mono - Fast
            ToySport Triton- Not as fast
            • riverside4
              • Jul 2008
              • 49
              Thanks for the info i got the old bushing out not much left ordered a new one gonna go for it and replace the stuffing tube. The stuffing tube was lined up but it just has one sharp bend in it. when i reinstall i will try to make a much more gradual bend(i hope)
