whats the fastest speed
  • rcboatfan
    • Aug 2008
    • 253
    what would be the fastest speed possible with the stock motor and esc on some very very high quality 4600 7 cell nimh batterys. what prop could i i get ect.
    thanks,
    rcboatfan
    SUPERVEE 27 37'' TWIN CAT
  • Boatman
    • Jan 2008
    • 796
    put a k45 prop on it and should see speeds near mid 40's.
    • rcboatfan
      • Aug 2008
      • 253
      wow, thanks!!!!
      • rcboatfan
        • Aug 2008
        • 253
        got a link to that prop??
        • RCprince
          • Jul 2007
          • 1637
          http://www.offshoreelectrics.com/pro...od=grp-2317.45
          • rcboatfan
            • Aug 2008
            • 253
            thanks!!
              • 9479
              I'm only getting 35mph using a CF48 with some awesome lipo batteries..
              Do I need a esc programer to get more speed?
              Help, I think it should be getting more speeds!
              • 785boats
                Wet Track Racing
                • Nov 2008
                • 3169
                Brushless.
                I personally think that a 48mm prop is too big & is loading up the motor which is keeping the revs down.
                I think an Octura M642 or M645 will find you more speed.
                rcboatfan.
                Try the M642 but the M645 may be too much for the nimh cells. Not sure on that. But for sure the K45 suggested by boatman is a good prop.
                Cheers.
                Paul.
                  • 9479
                  Even out of the water is sounds to me like the motor does not hit very high revs?
                  It is nuts out of the hole!
                  • z400
                    • 1311
                    rcboatfan
                    Im not sure if you've ran the boat on 7 cells yet or not, but make sure you run a BEC with that set up.
                    Z
                    KBB34" Mono - Fast
                    ToySport Triton- Not as fast
                      • 9479
                      this is on 2s x2 lipo batteries..
                        • 9479
                        Ok I adjusted the strut ( I think thats what it is called) because the boat acts like it is stuck to the water and picked up 1.5 mph, then my boat stoped! ahhh
                        the motor separated the front face plate from the can!
                        well I brought it home and fixed the motor.. I also noticed that my trim tabs are set low making the hull suck to the water as well. I moved them to 0* and will try again tomorrow..
