Battery ?
  • WaterWalker
    • Feb 2009
    • 23
    Battery ?
    Good Morning...
    Any reason (?) I can or shouldn't use (double duty) lipo battery packs, I also use on my Scorpian Krawler. Using 1 pack or both packs in the boat at the same time... One or Both fit OK...
    > MaxAmps 4000mah, 2S2P, 7.4v, dual saddle packs of which I have 2...
    Stock SV motor and ESC... and sure would save some battery $$$$...
    Many Thanks and Holler,
    Luke
    Sumter, SC
  • motoxbob11
    • May 2007
    • 190
    The SV uses 2 packs wired in series for 14.8 volts so you can use those packs together. The SV speed control is wired to accept them both. I assume they are just regular shaped packs.
    • WaterWalker
      • Feb 2009
      • 23
      Hi Motoboxbob11...
      They are both saddle packs... Ref: http://www.maxamps.com/Lipo-4000-74-Saddle.htm
      ?: Not sure how to put links on... ;( I hope it works...
      Holler,
      Luke
      • egneg
        • 4664
        Both packs together are 7.4 volts ... you would need 2 sets.
        IMPBA 20481S D-12
        • motoxbob11
          • May 2007
          • 190
          Yea I was confused about what you meant by saddle pack. Egneg is right you need 14.8 volts to run the SV so you need two sets which you have.
          • scoota
            FE DOWN UNDER
            • Dec 2008
            • 409
            just remember the stock sv speedie does not have low voltage cut off for lipos ,so there is a chance of running your voltage too low & killing your new lipos .
            UL1- 1515 castle/neu / 240 swordfish
            SV27- with UL1 running gear
            33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
