Help with SV27 and Fast radio
  • Toypainter
    • Jan 2009
    • 11
    I am trying to set up an sv27 with my Fasst radio and have a problem. I am new to FE boats, but have been in RC for 20+ years.
    Transmitter on, when I plug in the battery the ESC does a continuous beeping until I push the trigger to full brake. Then I get one beep (different tone than the the others), release the trigger- nothing- until I push full brake again, then the same single beep. Release trigger- motor starts. Will stop if I push brake, slightly accelerates when I pull the trigger. Runs continuous speed when I let the trigger go. I have tried setting trims, end points, everything I can think of, but nothing changes it. I even tried the ESC out of my brand new, never run UL1 with the same results.
    Any ideas? I'm totally stumped!
    T5hanks in advance,
    Rob
  • line6
    • Aug 2008
    • 478
    Reverse the throttle futabas come backwards. had this prob a few weeks back Bill-Socal straitened me out.
    • Bill-SOCAL
      • Nov 2007
      • 1404
      Also once you reverse the trim lower the throttle trim until it arms. Then you should be all set.
      Every single Futaba radio that I have ever used, in airplanes, helicopters and boats, needs to have the throttle channel reversed for the ESC to arm. Go figure.
      Don't get me started
      • longballlumber
        • 3132
        Agreed,
        I had to do the same with my Futaba 3UCP (stick radio) when I ran the SV.
        Mike
        • Toypainter
          • Jan 2009
          • 11
          I'll give it a try. Thanks guys!
          Rob
          • Toypainter
            • Jan 2009
            • 11
            That worked. Thanks for the help guys!
            Rob
