Why do you need a receiver pack when running 7 cells
  • Tbone2000
    • Jun 2007
    • 39
    Does anyone know why need a receiver pack when running 7 cell batteries? I have been running 7 cells in my SV w/o a receiver pack and so far no problems. I saw a warning on the OSE 7 cell ad and was curious.
    Will it fry the ESC?
  • ChaKane
    • May 2008
    • 131
    Usually 7 cells presents too much voltage for the BEC to transform into a usable voltage for the receiver. It will provide too much voltage to the receiver, blowing it and letting all the magic smoke out.
    • andym
      More Go Than Show Prop Co
      • 2406
      You will find that the BEC smokes before the receiver bites the dust. This can cause problems with the ESC. For a more reliable ie less glitching and better range a stand alone BEC or a good receiver pack are a better opyion. Good luck and I hope your boats get faster
      Andy
      • ibyte
        • Sep 2008
        • 83
        +1 on magic smoke. And like andym said it helps with the glicthing. If your 7 cell batts arent all that new you may be riding the fine line of its okay newer 7 cell batts might do you in just when you are having fun so be careful.
        • Steven Vaccaro
          • 8723
          All good answers. It seemed that people mostly experienced glitching and some major run aways when using 7 cells.
          • hex-dj
            • May 2008
            • 238
            Will like to know...???
            Steven .Could the type of reciever have some effect when glitching or the smoke occur?
            I have been using a DSM reciever with 7 cells and havent had that problem so far...
            • Steven Vaccaro
              • 8723
              A better rx wil mostly likely stop glitching, but not help from overloading the bec. But there is no definite right or wrong way. So far people have had both ways work and not work.
              • 785boats
                Wet Track Racing
                • Nov 2008
                • 3169
                If you are going to use external batteries or a UBEC it is a wise practice to remove the red wire & pin from the receiver plug on the ESC. Otherwise there are two different voltages being supplied to the receiver rails. They don't like that either. But also the BEC in the ESC is still activated from the 14 cells & getting hot & causing the original problem unless the red wire is disconnected.
                Regards.
                Paul.
