lol you guys are funny...enough already....What is It we like about the SV...hmmm..I like that fact that I have an outboard on mine...waiting for the winter thaw to whip some cats behind.....working on stopping it from leaking when it flips....
ESC Stock Cooling Issue/Fix
yeah im sure to love it and it be music to my ears , sorry off tracking , thinking of getting the titan 29 hull and build it from there ~ not sure what electronics to store in yet tho , still in the drawing board stage~known is a droplet, unknown is the ocean~Comment
I'm going to have to get a GPS then. More $, ugh. Kin, try a Feigao, they are a nice upgrade. The AMMO 2300 is a sweet upgrade to. They are sold by OSE. Here is the link: http://www.offshoreelectrics.com/pro...od=dh-gpmg5290
If you want something that is close to the Feigao 540 11L 2,234 RPM / Volt 5mm Shaft. 540 10L 2,458 RPM / Volt 5mm Shaft
As of now they are out of stock, but once in stock it's a great upgrade!
I noticed the same thing you did when I was cleaning out the obstructions in my cooling system. When I had the heat sinc apart I bent the two pieces back out the other way so they were concave. Then, during re-assembly, I tightened down the screws in a uniform and gradual manner with blue locktite. The heat sinc/cooler now sits flat on the top and bottom of the ESC.Comment
I'm glad someone saw what I'm talking about. But anyways I abandoned the stock ES for a Hydra 120. I never even used it!Comment
I know this thread is kind of old, but I noticed that mine is this way too. I bet they all come from the factory that way. It doesn't seem to matter how tight or loose the screws are. I can't imagine that it works very well this way. Probably just needs to be bent a little so that the heat sink actually touches the ESC. Or, just buy a Castle ESC!Comment
hello, i had the same problem with the esc overheating but what i did is i went to radio shack and i bought ( Thermal Grease ) and i applied it in between the esc and the cooler, Thermal grease conducts the heat transfer better and up to now i have never had a problem.Comment
You can do that, but the idea behind thermal grease is not to act as a "filler" if there is a noticeable gap, rather it's to provide a "better" contact on top of an existing "good" contact. If your heat sink is flat, adding the thermal grease will definitely help like you already said it would.Comment
