ESC Stock Cooling Issue/Fix
  • SweetAccord
    Speed Passion
    • Oct 2007
    • 1302
    Greetings all,
    I finally received my SV27. In sup'in up my SuperVee (lots to do) the first thing I went for and saw a flaw in was how the stock heat sink was mounted on the ESC. It is theoretically well designed how it's to operate, but mechanically how it's assembled there is more to desire in the layout.
    Problem 1. If the screws on the heat sink are tightened it too much it concaves and does not sit flat on the ESC (loss of surface area and heat exchange) and obviously if it's not screwed down well it's not going to pass over the heat well to the heat sink either.
    Problem 2. The the heat sink water line connect sits way too low, and even if the heat sink is flat on the ESC, once tightened, it won't be sitting completely flat, because of the hoses hitting the ESC and raising the heat sink so once again there is surface loss.
    Solution: I will be cutting two pieces of flat aluminum plates that will be placed between (no pic as yet) the ESC and the (blue) heat sink on both sides which will allow all the the above issues to be resolved. This will allow the heat sink to clear the hose connects and sit flat once tightened down. I may also add some thermal grease to help the heat transfer along too.
    Hope that helps.
  • kin
    • Jan 2008
    • 55
    mine me saying this , crap ,,,,,,, too much of resistnce . just dun tighten it much to create that concave position u mention , adding a plate to it wont solve your problem.... ever wonder why no one replied to your post ... no one cares!!!!! or its just crap .. sorry again for the crap word tho ~ dun worsen your sv esc
    ~known is a droplet, unknown is the ocean~
    • kck741
      • Aug 2007
      • 265
      Wow those are some harsh words.I think the stock esc works fine Just dont over tighten the screws
      S.S.R.C-Southern Style Radio Control
      • kin
        • Jan 2008
        • 55
        sorry didnt mean to be harsh but its the true fact , sometimes we just over react and do things beyond thinking straight and trying to outsmart some experts who build the sv itself , just dun over tighten it will do, apologise if the word uses r harshed tho.
        • RCprince
          • Jul 2007
          • 1637
          Blackjack esc IMO has a better design, But hey the SV is a great Boat enjoy it have fun, research, experiment..It's all in the name of fun
          • Steven Vaccaro
            • 8723
            Kin we appreciate well thought out and constructive responses. We really don't need these kinds of responses.
            • SweetAccord
              Speed Passion
              • Oct 2007
              • 1302
              Ewwww....... I was just trying to point on that the plate bends. I'm not overreacting, don't know where that came from. Anyways, I work with many industrial motors and computers and circuit boards you have and will never see in your life including other small to medium electronic devices and circuits and I understand the details of cooling and heat exchange/transfer more than I come off to. Not tightening it does not provide enough contact surface area for the maximum cooling effect. When reaching temperatures above 100F that is very hot and electronic devices mostly fail above their design. If you feel it does then kudos to you. I know it can be better. To some that may be important to gain all the advantage to some they won't care (hence no post?) Any change is about the change being part of one change that will make the difference in the summation of the whole.
              "Experts?" I would not say an expert designed the heat sink on the ESC. First flaw is the water line connects are way too low hitting the ESC. Any one with 1 year in mechanical design 101 would have given more clearance for may different reasons. I can name a few. There is some things that may/can and have been improved on (water pickup, hull, radio etc. read more posts) on the SV, hence all the parts that can be purchased and added, but yes out of box it's fine, depending what "fine" means to you. Again, some people may care for out of the box performance while others seek for more.
              I won't be using the stock ESC anyways hence null point anymore, but a plate would work if created if you look before you leap, the thickness where the screws pass through are thinner than the contact plate area. So making a plate that would be the same surface area that the screws would pass though would NOT allow the plate to bend when tightened down more.
              It doesn't bother me that no one replied, I'm sharing my information and there were may views on the post which tells me it's not all about answering, it's about reading and gaining knowledge. I read many posts and do not reply by the way.
              • motoxbob11
                • May 2007
                • 190
                I didn't reply because I just got home!!! I noticed the bend also but since the cooling tubes are so far to the ends I figured its not a very effective design anyway so I'm not going to worry about it. I think Kin should also not worry so much and calm down a bit. (A spell-checker would help also)
                My thought is that with stock power levels and sane prop selection the stock unit should be fine.
                • SweetAccord
                  Speed Passion
                  • Oct 2007
                  • 1302
                  Yeah man, for stock it's fine. I'm not doing stock here though. If he thinks that much of such a small item it pointless, go look at 10gauge's thread: http://forums.offshoreelectrics.com/...ighlight=water that should make ya rip your hair out!
                  Spell checker, <Bwahhahahaa.........now that was funny!!!
                  • Bill-SOCAL
                    • Nov 2007
                    • 1404
                    First, as noted, if you are torquing down on the bolts so much that you are bending the plates, that is TOO MUCH!!
                    Second, if you tighten them the right amount the clearance between the tubing and the body is DESIGNED to help hold the tubing on. It is NOT a flaw, it is meant to do that.
                    Oh well. Try to have fun with the boat. It gets much maligned, but it is a great value and it really is a good boat. I still run mine every time I go to the lake, and I've got 6 other boats to choose from. It is just a soild little fun boat that does everything a race boat should.
                    Don't get me started
                    • kin
                      • Jan 2008
                      • 55
                      my bad ~ but i`m sticking to my guns on a frenly manner here .....
                      ps; i apologised but no no one seem to take my apology ,
                      • SweetAccord
                        Speed Passion
                        • Oct 2007
                        • 1302
                        Apology accepted, No worries.
                        • kin
                          • Jan 2008
                          • 55
                          anyway i think i may upgrade to a hydra 120 esc with feigao 9xl motor with one of the grimracer 3 blade prop real soon , hope to see my sv rocket at full throttle tho , still working on the CG ....... LOL
                          • SweetAccord
                            Speed Passion
                            • Oct 2007
                            • 1302
                            I love the boat, no doubt. There is just more to desire in the design. As for the ESC, well Like I said I'm not using the stock ESC so mute point anymore.
                            But I have to disagree that the tubing is to be hitting the body to help hold it on. Bad idea, that is what the flanged lip on the brass fitting is for, and making it hit the body to "help" is a patch then as then the plate is not sitting flush on the body of the ESC.
                            I would not make the tubing to be touching something that is hot or even warm, that is a failure ready to happen in my book may take forever but think about it. But once again, most won't care and think it's fine. I look at every little thing how and why in a design. Placing a rubber item on a heated object to say it's to hold it makes little to no sense, sorry.
                            I'd like to see a car manufacturer or any system that uses some type of cooling design an engine for example and position the cooling hoses and flush them up against the engine and say "Oh we flush the hoses on the hot engine to hold them down." I'd laugh in their face!
                            • SweetAccord
                              Speed Passion
                              • Oct 2007
                              • 1302
                              Kin, you will like the Hydra, it's well designed, nice instructions clear and easy to understand.
