New SV27 owner
  • Brushless01
    • Apr 2010
    • 487
    http://www.offshoreelectrics.com/pro...dh-SB-aqub9725 balanced and sharpened i just got one super sharp
    Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
    • Jmauld
      • Apr 2010
      • 28
      Originally posted by Brushless01
      Yes that is the prop the 42x55 is also a good prop but needs to be balanced and sharpened or you can get pre done on balanced and sharpened props.
      Any idea where I can find the CF45 in stock?
      • archuraas769
        • Jun 2010
        • 53
        I agree use, a cf 45 prop ( thats what I use) and as to ur second question it is normal for the water to get fairly hot, but if your not geting enough cooling to the ESC and mottor you can use this pick up http://www.offshoreelectrics.com/pro...prod=ose-80410
        • Diesel6401
          Memento Vivere
          • 4204
          CF props are good, I test with them all the time. I regularly use the 42x55 though. I enlarged the opening of the rudder pickup with a small rat file which greatly help increase the water flow. I currently use dual pickup though.
          - Diesel's Youtube
          - Diesel's Fleet
          • archuraas769
            • Jun 2010
            • 53
            • wizard122
              • 483
              Battery trays
              Have you removed the battery trays yet? I run the stock prop all the time when just running for fun and it planes well for me.
              2 SV 27's and Vac-U-Pickle UL-1 Power
              • wizard122
                • 483
                Did you try Kintec for your props?
                • wizard122
                  • 483
                  Battery location
                  Heres the way I run my packs with stock props.
                  • Insaniac
                    • 423
                    Originally posted by Diesel6401
                    Welcome to the forum. What part of NC are you located in? Here's a good cut-off http://www.offshoreelectrics.com/pro...hld-32&cat=136. Your going to need to remove the battery trays first and formost and recommended prop is a grim 42x55, try only to run lipos above 4000mah and at least 20c. Happy boating!
                    Watch out for that Deans Engineering LiPo saver...mine failed after about 5 runs and the manufacturer won't stand behind their product...destroyed an expensive LiPo. You are better off getting an ESC for LiPos...JMHO
                    Support US hobby suppliers
                    • Diesel6401
                      Memento Vivere
                      • 4204
                      Wow that sucks couldn't tell you how many runs I had on mine and never had one problem. I run ul-1 power for the last few months, so no lipo shield needed but like I said I never had 1 issue you must of got a bad 1. Sorry for your luck, I still think they are worth the price though.
                      - Diesel's Youtube
                      - Diesel's Fleet
                      • Jmauld
                        • Apr 2010
                        • 28
                        Thanks, I'll give that a try later this week as long as the weather holds out. I haven't moved them forward yet.
                        I also saw the 45 carbon prop at kintec and was considering ordering it.
                        • z400
                          • 1311
                          #27
                          Hey dude,
                          Its Sean from HPJ
                          Just noticed you made it over here
                          Z
                          KBB34" Mono - Fast
                          ToySport Triton- Not as fast
                          • BakedMopar
                            No Mo Slipah
                            • Sep 2009
                            • 1679
                            #28
                            I had one off these (dimension engineering) fail when my boat crashed and got fully submerged. I sent it back and they replaced mine for free within one week.
                            • Jmauld
                              • Apr 2010
                              • 28
                              #29
                              Originally posted by z400
                              Hey dude,
                              Its Sean from HPJ
                              Yeah, this place gets recommended a lot.
                              I'm taking the boat out to Lake Jordan tomorrow, with the batteries moved forward. Hopefully it won't cavitate as bad as it did this past weekend.
                              • z400
                                • 1311
                                #30
                                I havent got your box shipped out yet, ive had alot on my mind.
                                It should be in the mail tomorrow first thing
                                Z
                                KBB34" Mono - Fast
