What gives ???
  • bmaxx
    • 27
    What gives ???
    I upgraded my motor to a Trinigy 2300kv 6 poll and a trinity 120amp esc running 40c 5000mah lipos 40/52 prop. and my buddy's bone stock SV with a cf 45 is faster than mine.... What gives???? It is defiantly not running wet, it is out of the water really well and corners really well on the course but just needs more mph in the straights.
  • Diesel6401
    Memento Vivere
    • 4203
    Do you have a link to the motor and esc? Maybe not the right prop for that motor, or maybe not the right motor timing. What is the timing set for? Motor timing from the esc should be high for a 6 pole. I would start looking at the esc settings, then if nothing changes try a different prop.
    - Diesel's Youtube
    - Diesel's Fleet
    • Steven Vaccaro
      • 8724
      What are the other motor specs?
      Steven Vaccaro
      • bmaxx
        • 27
        Motor From Kintec
        Turnigy B3656-2300kv These are 6 pole 2300kv with a 5mm shaft. Comes with 4mm bullet connectors. $35.00ea
        Spec.
        Kv: 2300rpm/v
        Power: 400W
        Turns: 6
        Resistance: 19
        Idle Current: 2.8
        Esc: 45
        Battery Config: 3-5S
        Length: 52mm
        Width: 36mm
        Shaft: 5mm
        Weight: 230g
        And esc
        Thanks for the help guys.
        • Diesel6401
          Memento Vivere
          • 4203
          I didn't know the turnigy where 6 pole motors. If it is a 6 pole try adjusting the motor timing, I would pop a end bell and take a peek inside to see how many poles it was just to be sure though. Then you can properly adust the esc. Just my 2 cents.
          - Diesel's Youtube
          - Diesel's Fleet
          • bmaxx
            • 27
            Do I need to adjust my timing with my esc, or on the motor??
            As you can probably tell I do not know to much about electric set ups.
            • bmaxx
              • 27
              Well I figured out the programming I think it was at 15* so I moved it up to 22.5* hoping I can sneak out and try it today
              • m4a1usr
                Fast Electric Addict
                • 2032
                If your buddy is running the stock motor then it could just be available power. You list the spec's for that Turnigy at 400 watts. The stock SV27 motor can put out close to 700 watts. And I have read lots of comments on different sites (mainly A/C or helo) that say you cant get the advertised wattage out of a Turnigy. I dont know that for a fact and dont run any of those motors but it really might come down to that motor is not up to the task you seek.
                John
                Change is the one Constant
                • v-spec
                  Banned
                  • Jun 2009
                  • 940
                  What batteries is your buddy using? And what prop are you using?
                  • bmaxx
                    • 27
                    Thanks for the info guys
                    He is running the same batteries as mine but only 20c and mine are 40c. I am running a 40/52 and he is running a cf45.
                    So the Watts are the power it can produce???
                    I just got back from my testing spot to see if the timing advance worked, and being a little excited to finally get out there, and to see perfect conditions. I accidently plugged the batteries together, instead of into the esc... ya that didn't end well. Back to waiting for the new batteries.
                    • bmaxx
                      • 27
                      I finally got out today with some new batteries, and the timing advanced to 22.5*.
                      Holey cow what a difference. It was able to easily drive buy my buddies SV, and was much faster on the top end, for about 3 laps.
                      I fried the esc and The motor as well. Not to sure if the the motor didn't hold up and killed the esc??? The water was flowing well out of the boat. and I was running the 40/52 prop, 30c 5000 lipo's
                      • Diesel6401
                        Memento Vivere
                        • 4203
                        746 watts = 1hp
                        To much timing maybe. I think those are only 2 pole motors, I don't use them though. Nice price, but not enough WATTS!!!!
                        - Diesel's Youtube
                        - Diesel's Fleet
                        • bmaxx
                          • 27
                          Thanks Diesel
                          I guess I am on the hunt fore a UL1 motor esc for it. Or pull the one out of my UL1 and jam it in the SV, and find something else for the UL
                          • Diesel6401
                            Memento Vivere
                            • 4203
                            A Feigao 540 12L will rock in a SV.
                            - Diesel's Youtube
                            - Diesel's Fleet
