Drew's SV
  • Drewmugx5t
    • May 2010
    • 35
    Finally done.
    Got everything epoxied in the way I want it. Everything turned out pretty nice except some of my epoxy joints ran a little (oh well). Very happy so far and I will see how it runs tonight.
    • Diesel6401
      Memento Vivere
      • 4203
      Nice work buddy, looks awesome!!!
      - Diesel's Youtube
      - Diesel's Fleet
      • wizard122
        • 483
        So how did it run Drew?
        2 SV 27's and Vac-U-Pickle UL-1 Power
        • Drewmugx5t
          • May 2010
          • 35
          It ran well but I didn't check the cog. I think I was running a little wet. I was running my batteries with the back at the blue line, which is the middle one, I am going to run it in the morning at the rear line and see where I'm at.
          I do think that the added weight made the boat slightly more stabile, but may have slowed its responsiveness in tight turns. before I could cut cut left quick then right, similar to initiating a drift in a car, and it would cut really fast to the right. Now it is much harder to do that.
          On a side note the stock prop that came on my boat, used, was torn up. I have only been running the 40mm carbon prop that kintec sells.
          I will report back tomorrow.
          • Drewmugx5t
            • May 2010
            • 35
            How much of the boat should be in the water when running top speed? It looked to me like there was about 6 to7 inches in the water to me. Seems to me that it was running about 5 inches in the water before. I think this is partially due to the fact that I was able to get so much reinforcement in the bottom of the hull. I was able to get the whole bottom except for the front 4 inches.
            • wizard122
              • 483
              Make sure your trimtabs are neutral and so is your strut rudder tucked under a little, CG at
              7.5" to start with it should run loose may even want to blow over then start to move the battery's forward a little at a time till you find the sweat spot.
              • wizard122
                • 483
                I forgot to ask are you running Lipos?
                • Drewmugx5t
                  • May 2010
                  • 35
                  #23
                  yeah. turnigy 5000 20-30c. I have some 5200 30-40c on the way from Hong Kong.
                  • Drewmugx5t
                    • May 2010
                    • 35
                    #24
                    Haven't had time to run it so it needs to go. Check for it on the for sale thread.
                    • Drewmugx5t
                      • May 2010
                      • 35
                      #25
                      Still for sale. New pics added today.
