Drew's SV
  • Drewmugx5t
    • May 2010
    • 35
    Drew's SV
    THIS BOAT IS FOR SALE IN THE "SWAP SHOP"
    I received it totally stock on Monday. This is what I have done so far, I have Glass and resin to do still but I wanted to get it laid out first so that i know I like where everything is. This is my first boat so let me know what you all think. BTW the radio tray is 1/8" Plexiglass. It fit perfectly into the slot that the stock box used in the back. I wanted it to be clear I think it looks a little cleaner that way. Receiver is in the foam on the starboard side sandwiched between 2 layers. This should be fairly water resistant should the need arise.
  • wizard122
    • 483
    Hi Drew looks real good can't wait to get together and run What type of foam did you use Pool noodles work best and your Rx will fit right in the hole i've got some if you need it. Wiz
    2 SV 27's and Vac-U-Pickle UL-1 Power
    • Drewmugx5t
      • May 2010
      • 35
      Its closed cell, that was part of packing for a tub we installed a while back. It floats and doesn't soak up water. Oh yeah I ordered some more batteries Wizard, some 5200 30C this time. Oh yeah I forgot to tell you that cooling jacket was so tight I couldn't get it on even without the o rings, I had to dremel off some material but its good now.
      • wizard122
        • 483
        you have to use Associated Green slim LOL those pins have to be filed down
        • Drewmugx5t
          • May 2010
          • 35
          LOL, Thats crazy B/c that is what I grabbed first when it wouldn't go. I sanded down the inlet and outlet too since they protruded a little for maximum flow.
          • wizard122
            • 483
            Very cool
            • Diesel6401
              Memento Vivere
              • 4203
              When you 2 want to get together? All sundays, mondays and tuesdays im off of work... boats looking good!!!
              - Diesel's Youtube
              - Diesel's Fleet
              • forescott
                Hopelessly Addicted to RC
                • 2686
                Nice, you will eventually want to upgrade that water pick-up. The stock turn fin pick-up works(not so good)
                • Diesel6401
                  Memento Vivere
                  • 4203
                  I had problems with my stock rudder pick-up until I opened up the hole with a small file and rounded the lower leading edge of the rudder, after that it was SWEEEEEEEET lol....
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • Drewmugx5t
                    • May 2010
                    • 35
                    I opened up the hole in the rudder. the trim tab adjusters come with a pickup if I decide I need it.
                    • Drewmugx5t
                      • May 2010
                      • 35
                      I can probably meet up Sunday. It kinda depends on whether or not I go to the nc champ series race Saturday. Its like 3 hours away so I will be worn out. Let me know if you are going and I'll try and make it work
                      • Drewmugx5t
                        • May 2010
                        • 35
                        Ran the boat again today for the 4th time and it ran perfectly this time with all the upgrades and setup tips everyone on here has given me. Very happy with my setup, only thing left is the hull reinforcing.
                        • forescott
                          • 2686
                          Cool! The sv is an awesome boat! Hours of fun!
                          • Drewmugx5t
                            • May 2010
                            • 35
                            Gutted it this evening. I'm going to build the rest of the radio tray etc. out of plexi. I saw someone else did it and I thought it looked cool. I'm sure it will be a tad heavier, but so is adding all that fiberglass and resin. Maybe the added weight down low will help stability.
                            • Drewmugx5t
                              • May 2010
                              • 35
                              Got some fiberglass from Home Depot to add a layer to the bottom and up the sides some. I used the kintec strips on the sides since it has a finished edge so that it looks clean. It took some time with the Dremel to remove all the excess epoxy from the original radio/ motor mount tray and battery boxes.
                              I got the plexi radio tray made, just need to let it set up. Almost done with it for now.
