speed
  • boatman cmbc
    • Feb 2010
    • 159
    speed
    whats the best speed ever got from sv27?
  • Doby
    KANADA RULES!
    • 7277
    In a set up you can actually control,,,or just in a straight line????
    Grand River Marine Modellers
    • m4a1usr
      Fast Electric Addict
      • 2032
      You mean whats the official speed record an SV27 has achieved? I think the racers at Valdosta set it at 49 mph. I seem to remember that number. Some folks claim to have achieved some very high speeds. Like over 60mph! I cant get mine that fast. And mine is 100% SAW. 1512/1.5D on 3S with a CC240. And I have plenty of unused power. Its just the hull becomes very unstable at high speeds and wont stay on the water. It will blow over almost every time.
      John
      Change is the one Constant
      • boatman cmbc
        • Feb 2010
        • 159
        speed
        thats what i thought ihave heard insaine claims of 50+ iknew that was very tall talk. its im possible to get much over 40-45 and still drive. i race mine every month and i am trying to take out a delta force knock off its proving to be very hard. i cant out turn him. ican get speed but not turning. can anyone help in this dept.
          • 7990
          Every hull has its speed limit, adding more power doesn't mean it will go any faster with reliability. The SV27 was designed for speeds in the 30s but can go a little faster. The root cause is too much lift and too short length. You can add weight at the CG, up to a pound to keep the boat on the water by balancing the lift forces with gravity. But eventually the boat becomes so heavy that it will not corner well. The way to beat the knock-off DF is to get a real DF.
          Some claims of GPS speeds over 50 mph are likely true. There is a huge difference between a GPS speed (where the boat only achieved the top speed for a few feet) and an official SAW record (where two consecutive passes over 330 feet long have to be recorded). The latter is far harder to do than it would appear to the uninitiated.
          • BakedMopar
            No Mo Slipah
            • Sep 2009
            • 1679
            Sorry to say but the sv just can't run with the DF. Even the clones corner as if it's on rails. Fqdawld has a 25" clone and I can't run with him. The Sv is a great funboat not raceboat.
            • wizard122
              • 483
              46.3 mph
              Hi had had some fun running 46 mph a few weeks ago. I know it's a little loose but thats the way i wanted to run that day it was a blast check it out.
              2 SV 27's and Vac-U-Pickle UL-1 Power
              • boatman cmbc
                • Feb 2010
                • 159
                speed
                what have you done to your boat too get that speed?
                • wizard122
                  • 483
                  Check out my posts
                  Check out my other posts I have lots of photos and set up tips.
                  • Doug Smock
                    Moderator
                    • 5264
                    John
                    Good memory John! That was Ole Reed Eagle, he fell just short of the 50mph mark.
                    There were quite a few SVs that took a beating that weekend, good fun watching those guys go at it!!
                    Doug
                    MODEL BOAT RACER
                    IMPBA President
                    IMPBA 19887L CD
                    NAMBA 1169
                    • boatman cmbc
                      • Feb 2010
                      • 159
                      speed
                      doug do they race sv27s somewhere other than the cmbc?
                      • Doug Smock
                        Moderator
                        • 5264
                        The Florida Wave Blasters race stock amd modified SV classes. There may be others but I'm not aware of them.
                        We had the Fastest SV 27 competition at a SAWs event at Blue Lake in Valdosta Ga. a few years ago. That is the event John was refering to.
                        Doug
                        MODEL BOAT RACER
                        IMPBA President
                        IMPBA 19887L CD
                        NAMBA 1169
                        • boatman cmbc
                          • Feb 2010
                          • 159
                          speed
                          i have the fastest sv in my club but it took a lot of $ to get it there. do you know if the widow maker 2900kv motor can handle 6s lipo power? how much can bl motors relley handle? how much is to much.
                          • BakedMopar
                            No Mo Slipah
                            • Sep 2009
                            • 1679
                            This is a 6s run. Was the first time on 6s so i used the smallest prop I had that day. Its really not that much faster than 4s with a highly modded prop with that setup.
                            This is the the SV27 with a Feigao 12l, Castle Creations Pheonix Ice 100, Octura X637 on 6s Turnigy 5000mah 30c Lipos.
                              • 7990
                              ...do you know if the widow maker 2900kv motor can handle 6s lipo power? how much can bl motors relley handle? how much is to much.
                              Any 2900 Kv motor on 6S is too much, even in a gear box. Most bearings won't handle much more than 50,000 rpm, but the small props we use don't stay in the water very long so efficiency is poor. Any time Kv times voltage exceeds 40,000 rpm you will likely not go any faster. That rpm is SAW-only speed with no other practical application.
                              The problem with the SV is the same with any model - it has a hull-limited top speed and even unlimited power will not push the boat faster. The boat has to stay on the water and the prop has to stay in full contact with the water to achieve top speed. The SV has too much lift over 50 mph to stay stable. You can add weight to help offset the lift. but that only helps a little. If you cannot get there with a 2400 Kv motor on 4S, don't waste your money on higher voltage and more expensive motors. Get a more appropriate model like a Titan 40 or DF33.
