What prop are you running? Too hot a motor could mean alot of things but it might be the stinger and rudder are not set correctly. As far as adding a water pickup,..dont. You dont need anything hanging off the transom or some addition to your stock water pickup in the rudder. Open the water inlet hole in your rudder. Make it bigger. Do not add anything to increase drag. The water coming in from the water pickup is more then enough to do the job.
Check your hardware first. Make sure your stinger is set to neutral, then ensure the rudder is at the same angle as the transom face. Trim tabs are an extension of the bottom ride surface. So neutral too. Now adjust your center of balance so the hull rides evenly and doesnt dolphin or porpoise. The guys who designed the boat did a darn good job of making it a good entry level setup.
You have a very well thought out design and equipment so make it work right. I know guys who are getting very respectable speeds out of their boats and other then adjustments and improving production imperfections they have not done anything other then add a decent prop. Heck, look at the stock class in NAMBA. Those guys are screaming and no additions!
John
John
