Hi try moving you batteries back a little that may help. What has your COG?
Supervee27 ?
Attached FilesComment
I use just a standard transom pickup found here on ose for my motorAttached FilesComment
Government Moto:
"Why fix it? Blame someone else for breaking it."Comment
I did slide my lipo's farther foward than i normally do . so i will move them back a little & try again . If that does not bring the temps down. then i will install the trim tab water pick up i have have & then try again. thank's for the help.Comment
I think I run my batteries about 2"- 2 1/2" forward of the motor mount...NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
Whats up Mike, small world to see you here too ?
Havin' fun w/your Vee ?
I'm going to convert my 48" or buy my buddy's 40" to build but thinking of another SuperVee myself to play with in the mean time during assembly ?
Where do you run yours at in Largo ?
BondonutzComment
BondonutzComment
If weather permits Your more than welcome to join us Sunday ? There was about 15+ guys out at our little lake last Sunday and had a great time. One of the fellas has a Kayak and we set up markers. I should be receiveing my Vee Friday,anxious.
When I had my last Vee I didn't hang out with anyone whom ran boats, now theres a bunch of guys so it should be more fun this time around.
You have my #, gimme a call if interestedComment
another temp ?
As i stated before i went to a cf45 prop with the enlarged stock rudder pick up & the temps were 115 on the water jacket & 145 on the open endbell & 108 on the lipo's . I then tried the trim tab pick up only & the temp's stayed the same . Today i used both pick up's together & the temps stayed the same . The lipo's are about 1 3/4 inches past the motor mount . Any idea's ?. I was thinking i may go back to the stock prop as the speed seems the same with this prop . But the boat gets on a plan quicker with the cf 45 prop . This temps are after appromimently a 8 - 10 min run.Comment
My boat ran like that also. My favorite prop is GrimRacer 40/52X3 runs cooler and very fast 39.4 mph
also try running your lipos farther back till it gets loose then move them back alittle post some more pics.2 SV 27's and Vac-U-Pickle UL-1 PowerComment
I run a CF45 and CF48 for about 6-7min and my temps are much lower than yours..
also it sounds like my batteries are placed like yours to.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
Im not sure as i did not look at that before i disonnected the lipo'd from the charger. Im, pretty sure it's over 2600. My packs are neu 25c 2s 4900's The pack was close to the lvc when i stopped, if that helps.Comment
