Rio EP Pics!
  • hyrulejedi86
    • Aug 2009
    • 494
    #46
    well it's a 30c 1300mAh so that could still be too much. I just don't know. I hate to have to wait but I might have to wait until my new equiptment comes to run it.
      • 9488
      #47
      that's only 39amps!
      not all that much, the volts could be the issue, not sure how long the esc will last on 3s
      • hyrulejedi86
        • Aug 2009
        • 494
        #48
        I guess I'll just wait for the upgrades and not chance it.
        • hyrulejedi86
          • Aug 2009
          • 494
          #49
          I was taking a look at the Rio Ep and I was wondering if anyone has worked out how to get into the waterproof compartment without damaging anything? That is besides just using the removeable clear cover.
          I withdrawl my question. You can get to anything through the opening the clear plastic piece covers. Just in case anyone else would wonder.
          • soulreaper
            • 58
            #50
            Hyrule in my post "Rio my thoughts" I mentioned that I tried this boat first with a 2cell lipo and then I ran a 3cell 3000mah 30C. This woke the Rio up. I ran the boat for about ten minutes and everything was still fine. I plan on running this boat with a three cell until something smokes, but I think this esc can handle 11.v no problem. This is my opinion.
            • hyrulejedi86
              • Aug 2009
              • 494
              #51
              Well, that's good to know. I might have to give it a try then!
              Thanks for the reply
                • 9488
                #52
                Use clear electrical tape on the hatch and it will seal up all real nice
                • hyrulejedi86
                  • Aug 2009
                  • 494
                  #53
                  and they even included some clear scotch-like tape with the kit too!!
                    • 9488
                    #54
                    Have you had a chance to run it on 3s yet?
                    mine will be hear on wed..
                    • hyrulejedi86
                      • Aug 2009
                      • 494
                      #55
                      I havent as I have a deans connector on the battery and the boat has those white clip connectors. i have to find a spare male deans to install before i can do that. I did however find an old battery that will work.
                      • hyrulejedi86
                        • Aug 2009
                        • 494
                        #56
                        So, I was looking at the motor and the size of that area. I was wondering if a motor mount that the brushless motor physically screws into is going to be neccessary because of the increase of power. Since, the stock motor only has a bracket that goes over top of the motor does anyone have any suggestions of a mount that would fit?
                        So far as I can figure, the holes are about 50mm apart.
                        Also, I was wondering if 2.85 per cell is too low of a voltage cut off. I'm asking because an ESC I found allows you to choose the cutoff voltage and they allow you to choose between 2.6/2.85/3.1V per cell.
                          • 9488
                          #57
                          The stock mount should work just fine with a 540 can..
                          and the lipo cut off, I would stay with the 3.1v setting and no lower.. IMO
                          • hyrulejedi86
                            • Aug 2009
                            • 494
                            #58
                            So, my parts finally shipped to upgrade to brushless. I will start my own thread once they get here and I get started!!
                            • soulreaper
                              • 58
                              #59
                              As long as your motor is at a minimum 36mm in circumference it will mount using the stock parts. My brushless is 36mm and would not fit snug in the stock mount. I had to take the cooling coil sleeve and slide that onto my brushless and then into the mount and it snugged up perfect. I then took the cooling coil and carefully tightened it so that it would fit onto the brushless motor. I posted pictures on the "Brushless soon thread"
                              Reaper.
                                • 9488
                                #60
                                Awesome bro! Keep us posted, I may tag along with a new thread..
                                I'm going to get a brushless set up for my Rio ep this weekend..
                                What motor did you go with?
