Revolt 30 setup
  • Dlamazing
    • Jul 2014
    • 9
    Revolt 30 setup
    hi to all I've learned a lot from all you guys here and thanks I would have not gotten where I'm at today if it wasn't for you all we'll I need some revolt veterans help I just got the boat I did a lot of tweaking before it hit water since I've seen nothing but horror stories I upgraded the flex shaft and new AQ coupler since the factory one broke pulling the stock bent flex shaft I replaced all the connectors with 5.5 bullets battery,esc,motor all I also did the bigger cooling lines 4mm and re routed to esc first then motor by the way it's all stock 1800 motor n stock esc I set the turn fins kicked back and all the way up the strut I set it at true zero with the hull had to shim the strut bracket to achive this trim tabs are set even with the hull on the right side standing from the back of the boat and left is at credit card thickness above the hull line I sharpened the rudder all the way and rounded and sharpen as we'll the bottom of it it's also on a 4cell 5000mah pack and also have a 7200. 4cell pack also from turnigy both I'm stuck at 44.3 with a s/b m445 I see a lot of ppl here hit upper 40s with same set up can anyone guide me a bit to get there please battery also sits all the way back in stock tray
  • Dlamazing
    • Jul 2014
    • 9
    Also the brass shaft collet keeps coming out every time I drive it it backs up a bit any advise on how to keep it in there I put more grease on but doesn't help it stay in there :/
    • Luck as a Constant
      Make Total Destroy
      • Mar 2014
      • 1952
      If you're talking about the brass bushing, it's a floating design and is supposed to move in and out like that. Don't try to keep it in there
      • revoltrunner
        • May 2014
        • 646
        post a couple pics of the rear of the boat showing the
        hardware from the back and side.
        • Dlamazing
          • Jul 2014
          • 9
          • revoltrunner
            • May 2014
            • 646
            I can't see the shim on the strut bracket.
            did you angle the bracket up or down.
            • Dlamazing
              • Jul 2014
              • 9
              You can see it but it's on the right side on the boat standing behind it it's really thin also but the shaft is set even with the hull up and and and side to side true zero
              • revoltrunner
                • May 2014
                • 646
                my boats at my weekend place right now.
                I will get some pics of my setup and post them
                this weekend. mine runs 50-52 mph all the time.
                • Dlamazing
                  • Jul 2014
                  • 9
                  Thanks I would appreciate that a lot damn that's fast! On the stock setup!! What prop are you using? And what temps are you getting? I would think your cutting it close pushing that speed unless you got some nice cold waters here in Miami fl isn't the case the sun puts a beating here lol
                  • revoltrunner
                    • May 2014
                    • 646
                    my prop is a Octura x642 s/b
                    the lake I run in stays pretty cool most
                    of the summer,its spring fed.
                    my turn fins are all the way up as yours are
                    but I angled them back as far as they would go.
                    I tweaked the strut depth and angle many times before
                    it would run they it does. my strut is sticking out above
                    the mount about a 1/4" with around a 2 degree positive angle.
                    take that shim out and try that depth and angle.
                    check your flex shaft alignment at the motor coupler.
                    I had to put a washer under both front motor mounts so
                    the flex shaft would side right in the coupler without having
                    to push down on the coupler a little. also make sure your prop shaft
                    is not getting into the Teflon liner. mine was going into it about a 1/4"
                    I run 2 5000mah 2s batteries all the way back in the tray side by side.
                    I have my rudder angled back a couple of degrees too.
                    Mike could help you also. he has his running the same speeds.
                    http://forums.offshoreelectrics.com/...90-Mike-Caruso
                    • Dlamazing
                      • Jul 2014
                      • 9
                      We'll I did some tweaking to it yesterday i left the strut with the shim so it's parallel with the hull side to side but I did angle it up a bit and put the trim tabs on neutral and went up to to 46.4 mph it's running a bit more loose then what it was and the electronics temp dropped by like 20 degrees gonna try moving the rudder a bit back see if it loosens up a bit more since it was running so wet I also ordered a x642 see if that will bump me a little more also thanks for helping me gonna try n get it to were you ppl at
                      • revoltrunner
                        • May 2014
                        • 646
                        getting the prop up a little is what lowered your temps.
                        try just a little more up angle on the prop and see if that
                        loosens it up a little more.
                        just run it and tweak it till your satisfied.
                        I probably made 20 very minor tweaks to mine
                        before I got it to run the way I wanted it to.
                        that's part of the fun though....lol
                        good luck and have fun.
                        this guys boat runs very similar to mine.
                        notice how much of the hull is out of the water
                        on the straightaways.
                        • revoltrunner
                          • May 2014
                          • 646
                          I got all the way up to my weekend place and
                          realised I forgot my camera. i'll try to
                          borrow one from somebody and get some pics.
                          • revoltrunner
                            • May 2014
                            • 646
                            here's some pics. sorry it took so long.
                            • Rob Duckering
                              • Jul 2014
                              • 19
                              You should round off the bottom of your rudder
                              Rob Duckering
                              Namba #899
                              69 pay n' pak
