Poor fit of prop to stub shaft. Video included. .007"of slop, is this normal?
  • tlandauer
    • 5666
    I am using a grim Racer 40x52/3 prop on an OSE shaft, I have to push quite hard for it to slide up to the drive dog. May be just sloppy production, and I know how frustrating it is to you. Regardless of which way you are going to go, buy an up grade cable/shaft. I believe you will be much happier! Never any problem with OSE up grade item. AC stock shaft is an item you need to replace ASAP anyway. Let's just leave it like that, no bashing brands.
    • Mike Caruso
      • May 2012
      • 940
      Originally posted by Snowboard_Nut
      I had thought about a sintered bronze bushing sleeve, but an accurate holding fixture could get very complex due to mold flash and other imperfections on the hub surface, and it may only work on one size of prop if it relied on blade position. I am going to try some .003" shim stock and roll it into a "C" shape with no overlap at the ends and then attempt to slide that inbetween the prop and stub shaft. What is it about the collet that you dislike? Only 1 setscrew? Or the jaw design of the collet? How many jaws are in it, versus a upgrade like Kintec? I really don't like the idea of cutting the stuffing tube, I prefer to have the end of the tube as high as possible for peace of mind of water entering more easily if the boat stalled and took along time to be able to get to. I understand the benefit of an upgrade flex, as in the larger diameter wire being used, but is the stock flex soldered at the ends, or welded? It seems I see a lot of talk of upgrade flex's being welded ends. And i'm having a hard time understanding the tubing between the collet nut and the stuffing tube you mentioned, is this to prevent water "walking up" the flex like an Archimedes Screw, or are you saying this relieves the contraction of the flex cable under load? Do you have a picture of that?
      Collet single screw no problem it's on the cable end. The AQ first collect had three fingers that held the cable they broke too brittle heat treat. The second style has four fingers seems much better. Brass tubing 1st make sure you cannot move it by twisting. If you can just pull it out ruff with 80 grit and reinstall with Shoe Goo I added a support with wood and West Systems Epoxy. Distance between the collet and brass tube on mine is maybe 1/4 I fill that space with fuel or water hose that just slips over the cable. it will also just barely rub on the Teflon liner which help keep the water from coming up the cable in to the boat. I run a .150" cable in my boat. I solder my stub shafts onto the cable. I takes prep work on the cable to get all the oil out of it before you tin the ends. Yes tin the end that goes into the collet too.
      All my pictures are in the Gallery just do a search from Mike Caruso. If you look close you will see I also added thin wood the the front and back of the motor mount blocks too. My boat has been trouble free because I did all the upgrades before it hit the water for the first time. 40 years in RC boating has taught me not to rush things.
      Do It Like You Mean It .....or Don't Bother
      • Cooper
        • Jan 2011
        • 1141
        I know you are experienced in quality tolerances but NO drive line is balanced. In my opinion it is a must to at least balance props. You really don't have to but an unbalanced prop will just speed up the process of wearing things out.
        1 impossible to balance a flex shaft
        2 drive dog can only be balanced if you permanently attach, as any adjustment to set screw unbalances it
        3 retainer-nut or bullet, both ways need to be balanced
        4 bushing inside stinger will not wear evenly
        5 impractical to be using bearings and would need needle bearing if used
        6 collets aren't balanced, some better but will be spending $40+ for one.
        7 any gap in Teflon/tube/flex will oscillate resulting in imbalance
        8 even if all these were perfect a good coating of grease throws it all off.
        That's the reality of it. Now I'm not saying those things can't be done but at what level are you willing to take it to? I have some setups that I'm running over 50k rpm (saw only) and I do take great measures attempting to balance as much as personally possible to lessen imbalances. But it is just a necessary evil we can only minimize but not eliminate. But you are on the right track and in my opinion a balanced prop in a necessity. I have a pursuit that I just plug and play, even run damaged props, and at end of season I might have to replace the bushings. Opposite side of that I ran my saw cat knowing the prop had a very slight nick it it and that resulted in the stinger being torn off, broken shaft and lost that prop that had a lot of work into it. One of those things I kicked myself in the but for because I knew I should have repaired it, not one more run it. Lol,,,,, I think the welded flexes from kintec are great, sometimes a little sanding is needed. But to me it sounds like you just got a sloppy prop, I don't think that is common, but as others said some things to combat the loose tolerances. Good luck and you are willing to do way more that most do, as it's only going to be a benefit
        • Snowboard_Nut
          • Apr 2013
          • 10
          I am using a grim Racer 40x52/3 prop on an OSE...
          what kind of speeds are you getting? whats your battery?
          I agree, No Bashing, just recommendations from other experienced and HAPPY pilots of this wonderful boat....
          • Cooper
            • Jan 2011
            • 1141
            these are all from kintec, some new and some used. Welded shafts, ground, pretty good in my opinion. More pics but you get the point, I think only one was 187, all others were 1875, even the lightly used ones.
            • tlandauer
              • 5666
              I am so so sorry, I meant my prop fits well on an OSE shaft. I use that prop for my BBY Zephyr Hydro. Sorry to confuse you, man. Anyway, as I said, it really is a tight fit, of course I did not measure, I am not a machinist by trade, but I understand your frustration.
              here is my last run on that hydro:https://www.youtube.com/watch?v=uzLh_xD0k1U
              Not that it's that impressive speed wise, but hey, I am happy with even little progress on my part setting up the boat.
              • Snowboard_Nut
                • Apr 2013
                • 10
                That convinced me. I ordered a Kintec.
                • Cooper
                  • Jan 2011
                  • 1141
                  #23
                  And this is why I love the forums, you got me thinking about tolerances so I thought I would check. I make my own and this discussion got me thinking about a problem I was having, the shaft had bent and was causing problems. I just didn't think about checking but reading this gave me new perspective to my problem. So thanks for the post and keep the questions coming. :)
