Brand new Revolt. Took the prop off to sharpen and balance before the initial run. Right away I notice horrible slop in the fit of the Grim Racer prop to the stock shaft. I am a machinist by trade, and so of course I immediately start taking measurements and discover a .007" of slop in the fit. The prop's ID measure's .191", and the stub shaft measures .184"... The inside of the prop ID looks rough, almost gaulded as though the drill bit was not oiled as it was drilled. So, in regards to both the prop and the shaft, is this level of inprecision to be expected? I would think the stub shaft would be made of stainless center-less ground material resulting in a perfect 3/16"(.1875")...
Poor fit of prop to stub shaft. Video included. .007"of slop, is this normal?
Brand new Revolt. Took the prop off to sharpen and balance before the initial run. Right away I notice horrible slop in the fit of the Grim Racer prop to the stock shaft. I am a machinist by trade, and so of course I immediately start taking measurements and discover a .007" of slop in the fit. The prop's ID measure's .191", and the stub shaft measures .184"... The inside of the prop ID looks rough, almost gaulded as though the drill bit was not oiled as it was drilled. So, in regards to both the prop and the shaft, is this level of inprecision to be expected? I would think the stub shaft would be made of stainless center-less ground material resulting in a perfect 3/16"(.1875")... -
Thanks Cooper. If I were to buy an Upgrade Cable Assembly from Kintec that claims it's made in the USA, I should get a true .1875" stub shaft, correct? And as far as the prop, is Octura made in the USA? Are they more precise and better QC than Grim Racer props?Comment
I have heard that ABC make Grimracer props which is a good prop manufacturer in the USA, ive just measured some of my ABC prop bores & they are also .191" - .1915". They have an acceptable fit on my .187" stubs but I understand how much looser it is on a .184" stub.Comment
http://youtu.be/ZU61XhCPac4
Before you run the boat replace the Collet, Cable and add front and rear thin wood to the battery tray and it will last like mine even holding the Grim 4s battery.
It is a great boat for $$$ spent and will do u turns at 40 mph like you cannot believe. .150 drive cable not made for big props and Drag race starts. I run Hughey and Octura cables with Teflon liner BUT the reson mine does not walk up the tube is I add a very short piece of hose between the (cable nut) collet and stuffing box tube. If you change collets just trim off what you need from the end of the stuffing box tube.
Good luck.
MikeDo It Like You Mean It .....or Don't BotherComment
Oh ya cut off those Deans wire connectors and install something with 5.5 bullets there are nice ones out there that are polarized makes life easy. The ones on the motor to the ESC are fine just keep them clean with DeoxIT D5. Buy some Corrosion-X for RX just open it up squirt it all over the board inside, inside the motor. Then relube motor bearings just some good Syn lube I like SIN Lube from ACER Racing.
Oh and by all means buy a tube of Shoe Goo and take ever screw out of the transom seal the threads and then check it in the bath tub. Shoe Goo fixes everything at the pond LOL.Do It Like You Mean It .....or Don't BotherComment
[QUOTE=At home most of us guys have to use JB Weld and a tooth pick to fill the low spots and ream after words will also get you to where you can balance it with a fairly good fit.[/QUOTE]
I have never heard of this? Been running 25 years. Just balance and tighten the nut. You guys are way being way to anal on the sizes.Comment
Are your shafts and stubs available in the US? Are you using cold-rolled steel bar, or center-less ground high precision stock? stainless or steel? Have a website?Comment
I met with one of my club buddies today for a little test session at our club lake. He brought his new Revolt with him just so I could take measurements. He already had the prop taken off and onto another boat but I did get to measure his stock stub shaft and his was even worse at .182" !!! yikes! not impressed! and based on a previous comment on this thread is seems Grim Racer Props are running pretty consistent at .191" so he probably has .009" of play.... This seems unacceptable after reading so much about how a perfectly tuned prop makes so much difference, what's the point if the prop won't run concentric because of it's mounting scheme?Comment
Correct on all points. Grim props run well but first you have to fix the mounting hole so you can balance it right. With your whole machine shop you could bore the prop out and press in a sleeve done deal. At home most of us guys have to use JB Weld and a tooth pick to fill the low spots and ream after words will also get you to where you can balance it with a fairly good fit. 45X68 runs 48 mph on my stock powered revolt. Longer run time with the smaller std prop that comes with the boat.
Good luck.
MikeComment
Oh and by all means buy a tube of Shoe Goo and take ever screw out of the transom seal the threads and then check it in the bath tub. Shoe Goo fixes everything at the pond LOL.And I use Tri-Flow for all my motor bearings. I like the fact that it appears the motor has screws on the endbell so down the road it looks like we can replace bearings when needed. As far as transom leaks, I was leaning towards Plumbers Putty?
Pretty sure those red connectors are only 4mm, not 5mm....I used those in the past as well and they quite often "fused" together from the heat...go to 5.5 bullets.Grand River Marine Modellers
https://www.facebook.com/search/top/...ne%20modellersComment
Yup, they are 4mm. Oooops. Our club is buying 7 of these boats for club racing and we are going to use the stock props, stock motor, and stock esc. Think the 4mm will be OK under those circumstances? (I just ordered a bunch of the bare 4mm with sleeves). Our racing will be 6 laps.Comment
