i did all the changes before i ever put it in the water but i will change it back thanks for the info the esc change is just for adjustability of the lvc
Im Only Responsible For What I Say Not For What You Understand
The prop is simply too much, if you want a reliable setup that will be as fast as it was in the vid go for the 1900kv with an m445........................all the batt and cooling stuff is irrelevant, you have way too much prop.
I found issues with the stock motor bullets... both my revolt and my ul1, under a heavy load they simply FALL OFF. I suggest checking this as the motor will seem to not work; drop on some nice 5.5mm or so bullets with your own solder and golden.
i have 5.5 conns coming also for everything in the boat the motor never quit it just really slowed down but i thing it will work well in my recovery boat im building after it cooled down seemed to be fine gonna test it in my pool before i have to recover my recovery boat lol
Mine did not fall off or even feel loose, BUT, they were leaned up against the plastic battery tray and melted a hole in it! So obviously there is some high resistance in these smaller connectors? The only mod I have is a 45x68 prop, could this be why they are getting hot, if so what should I beef up? Is there any issue with soldering the small wires to the large 5.5 connectors? Some of these 5.5's state they are for a specific wire size, such as 10awg or 12awg.
Hi Tom,
I installed 5.5's on mine before it hit the water not on the motor side just the battery side of the ESC.
Well i replaced all connectors on mine took the water line spliter out and ordered two 4s packs 5000mah 40 c and shortened all the wires on eagle tree and esc hope this will help some
Sent from my DROID RAZR using Tapatalk 2
