Got my revolt
  • MAMBA2200
    I need a scooby snack
    • Jul 2012
    • 1202
    Got my revolt
    well i got my revolt yesterday overall i am very happy here is a few things i noticed
    -all the gear on the back is way loose (no biggy)
    -i got no owners manual or stickers
    -when i turn the prop the motor wiggles back and forth
    -there was nothing holding the hatch on so its scratched allot around the hatch hole (again no prob)
    - i do have lock nuts on all hardware thats a plus
    it almost seems like i got a boat that someone else had returned but i can fix all that is needed here is a video of the motor wobble
    Im Only Responsible For What I Say Not For What You Understand
  • Grimracer
    • Nov 2008
    • 662
    Hum.. No manual.. I bettter give you the contact info to Product Support.
    Call em and see if they can get you setup.
    Grim
    Hobby Services
    3002 N. Apollo Drive, Suite 1
    Champaign, Illinois 61822
    Attn: Service Department
    Phone: (217) 398-0007 9:00 am - 5:00 pm Central Time M-F
    E-mail: hobbyservices@hobbico.com
    Also.. here
    • MAMBA2200
      • Jul 2012
      • 1202
      thanks grim i have contacted omni thats where i got it from but so far have had no responce will give them a chance to make it right first
      • bruceisla
        • Aug 2012
        • 53
        You appear to have either a bad coupler or a bent motor shaft. Try removing the coupler and spinning the motor shaft to see which is bad. It's possible the coupler is cross threaded. Video is a bit shaky and too short to look closely.
        • MAMBA2200
          • Jul 2012
          • 1202
          well they are sending me the missing item and i think the wobble is flex shaft which i have already got the upgraded shaft so all is good i can fix the rest
          • MAMBA2200
            • Jul 2012
            • 1202
            got my seaking 120a V2 and 150a eagle tree time to start the build as everything will be here today photobucket-41902-1348319541628_zps6eb26191.jpgphotobucket-35208-1348319555490_zpsa5d93341.jpg
            • Mike Caruso
              • May 2012
              • 940
              Originally posted by MAMBA2200
              got my seaking 120a V2 and 150a eagle tree time to start the build as everything will be here today [ATTACH=CONFIG]84896[/ATTACH][ATTACH=CONFIG]84897[/ATTACH]
              Check out my gallery I mounted the ET to balance the boat out side to side. Aeromarine flex collet and Hughey shaft is what I am running trouble free. Stock prop runs good 45x68 pulls more amps but adds mph.
              Have fun man.
              Mike
              Do It Like You Mean It .....or Don't Bother
              • MAMBA2200
                • Jul 2012
                • 1202
                well i got the rest of my parts and it was the flex shaft bent i dont see how they crammed it in there gonna call aquacraft today and see if they will send me another because this one is crap but i have the upgraded cable installed and all is wellphotobucket-15101-1348492385892_zps7b975a8e.jpg
                • bruceisla
                  • Aug 2012
                  • 53
                  Well .... you may be expecting a bit much. Flex cables flex .... that doesn't look like a kink (sharp bend).
                  • MAMBA2200
                    • Jul 2012
                    • 1202
                    this i know when i pulled the old one out it had like a 45 degree bend on the end of the cable
                    • stadiumyamaha
                      • 1284
                      I wouldn't bother getting them to replace the stock flex. They are so suspect that you don't want to risk losing a good prop. Many times they fail in the first couple of minutes. Jmo
                      white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1
                      • MAMBA2200
                        • Jul 2012
                        • 1202
                        i hear ya think i will take that advise
                        • MAMBA2200
                          • Jul 2012
                          • 1202
                          well its all done and ready for its first run here is some final picsphotobucket-35263-1348580145245.jpgphotobucket-26975-1348580127743.jpgphotobucket-18967-1348580114016.jpgphotobucket-35347-1348580158128.jpg
                          • ktodd
                            • Sep 2012
                            • 5
                            Looks great! Looks thirsty for water Let us know how it runs
                            • MAMBA2200
                              • Jul 2012
                              • 1202
                              will do im off thursday thats when the maiden voyage will be and i will video it and post it up
