Depends on bearings.
If its a radial ball bearing it will only take a small amount of thrust. If its angular it can take some more. However thrust loads are not what they were designed for.
A thrust bearing in larger applications is a good idea. There is no real con against using one... The added weight or rotating mass is negligible.
I know a few things about bearings. My last machine I was Project Engineer on I utilized a 126" thrust bearing special made in Thailand. I also utilized a ton of tapered roller bearings in spindles as it was a tube mill.
